![]() | Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Home oil changes with the Draper suction pump is another active thread on this forum. A few of us have them and do home oil changes although yet to do my first |
Have you checked for any intake leaks yet in the hoses ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
JLR own bulletin :
yep. Its going to get a oil change before anything else and then a smoke test on the pipes. |
All that JLR stuff does not relate to our engines is my understanding.
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
The Oil Dilution is an inferred value.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
Dr Rob,
Dolphin boy,
Yep it sits on a magnet and i just reach over and squeeze both sides to "snap"
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Dolphin you might want to read through the DPF testing section of the workshop manual.
Just been for a test drive and now more probs than before!
Oh yes, one other thing. Anyone know how to reset the oil dilution figure if does that go out on resetting the service schedule? |
Dolphin your 'restricted' which clears on restart is consistent with split inlet hoses.
