![]() | Home > Technical (L322) > DPF full. see dealer message out of the blue.Sensor failure? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Greg - perhaps you could offer your DPF clearing service with your new box of tricks |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
@Greg,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hi Dolphin have you got any message on dash?
nothing. No faults or signs on the dash at all. |
Actually at 26g you are a knat's away from a RED:
But even a short drive will take you over 27.5 trust me. I'm not sure about the cause because you said you got a restricted and DPF full message, that's right isn't it? I'm not convinced it's a sensor TBH. Right now you really need to get a garage or a device like the DA-DPF or Nexas to do a forged regen . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Right,
Lucky break.
This is a null / not populated value Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 15th Oct 2019 9:54pm. Edited 1 time in total |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
My iid is the same version as Greg’s.
Just to add Dolphin, setting up the screen like mine so you can see those temps is essential, seeing above 600 is the only way to know it's actually happening.
BTW Your DTC code just means your DPF was saying it was full.
The field I have on my IID (and some others) is "Diesel particulate filter soot concentration - inferred using differential pressure". It appears that recent IIDs have this instead of an earlier field that was "Non Continuous Soot Mass" - as per Greg's screenshot above.
That's right DrRob, newer IIDs (or if you carry out the software update) have revised fields. I've not updated mine.
Rob,
