Home > Maintenance & Mods (L322) > Abs fault |
tabbahenry Member Since: 22 Mar 2016 Location: shetland Posts: 5 |
On my 2007 tdv8. I damaged my drivers front abs sensor. So I changed it out for a new after market one . Now abs lights wont clear . And fault code wont clear . And hdc wont work and air suspension wont work . The code am getting is . speed sensor signal has too few transition/events. So is it the sensor . Or are they something else I need to look at . I do have a genuine land rover sensor coming but being were I stay it takes a we while to get here. |
3rd Oct 2019 12:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
i would start with replacing the sensor with genuine one.. ... - .- -.
3rd Oct 2019 12:07pm |
MBR Member Since: 29 Sep 2012 Location: Tongue Posts: 23 |
I had a similar problem and it turned out I needed to replace the reluctor rings.
3rd Oct 2019 12:23pm |
I wouldn't think that it would be the ring on the cc joint . Because all am done is change the sensor . The reason I changed it is I managed to cut the wire by mistake. So it wasnt a problem untill I did that |
3rd Oct 2019 12:36pm |
Hi all . It was the sensor . Fitted a genuine one and cleared right away |
5th Oct 2019 4:02pm |
result.. ... - .- -.
5th Oct 2019 4:04pm |
