Home > Maintenance & Mods (L322) > Abs fault
tabbahenry
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Abs fault
On my 2007 tdv8. I damaged my drivers front abs sensor. So I changed it out for a new after market one . Now abs lights wont clear . And fault code wont clear . And hdc wont work and air suspension wont work . The code am getting is . speed sensor signal has too few transition/events. So is it the sensor . Or are they something else I need to look at . I do have a genuine land rover sensor coming but being were I stay it takes a we while to get here.
Post #529940 3rd Oct 2019 12:03pm
i would start with replacing the sensor with genuine one.. ... - .- -.
Post #529941 3rd Oct 2019 12:07pm
MBR
Scotland 2003 Range Rover Vogue Td6 Zermatt Silver
I had a similar problem and it turned out I needed to replace the reluctor rings.
Look into the hole where the sensor fits and turn the wheel to check that the ring is turning and not corroded or broken.
Hope this helps
Post #529942 3rd Oct 2019 12:23pm
tabbahenry
I wouldn't think that it would be the ring on the cc joint . Because all am done is change the sensor . The reason I changed it is I managed to cut the wire by mistake. So it wasnt a problem untill I did that
Post #529946 3rd Oct 2019 12:36pm
j_rov
is it fully home/flush and did you use the conductive grease? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #529948 3rd Oct 2019 1:25pm
tabbahenry
Hi all . It was the sensor . Fitted a genuine one and cleared right away
Post #530103 5th Oct 2019 4:02pm
result.. Thumbs Up ... - .- -.
Post #530104 5th Oct 2019 4:04pm
