![]() | Home > Maintenance & Mods (L322) > Lower ball joint removal-air hammer/chisel? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
SDS drill with a chisel?
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Yes that would do the same job probably.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
when i attempted to do mine I'd read lots of posts on here and elsewhere about it and it looked easiet to do by removing the hub form the car because access to the ball joint securing bolts is tricky as the CV joint is in the way and they are not hex bolts so can round off.
Blimey.
if fact you need a PUSHER to push the splined CV shaft out through the hub.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
We did the front end last month.
Thanks all.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Wise move, I'm about to do the same. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
its way when you know how......
