Home > Maintenance & Mods (L322) > Lower ball joint removal-air hammer/chisel? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
SDS drill with a chisel?
2nd Oct 2019 1:08pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Yes that would do the same job probably.
2nd Oct 2019 1:15pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
when i attempted to do mine I'd read lots of posts on here and elsewhere about it and it looked easiet to do by removing the hub form the car because access to the ball joint securing bolts is tricky as the CV joint is in the way and they are not hex bolts so can round off.
2nd Oct 2019 1:17pm |
Blimey.
2nd Oct 2019 1:39pm |
if fact you need a PUSHER to push the splined CV shaft out through the hub.
2nd Oct 2019 2:43pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
We did the front end last month.
2nd Oct 2019 6:44pm |
Thanks all.
2nd Oct 2019 7:32pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Wise move, I'm about to do the same. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
2nd Oct 2019 8:25pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
its way when you know how......
2nd Oct 2019 9:37pm |
