![]() | Home > Maintenance & Mods (L322) > Some news that nobody with a 4.2 wants to read... |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
Out of interest, what is VSR?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
valve seat regression - its since ford took over the engines apparently and used much softer metal for the valve seats compared to the Bmw counterparts.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
I remember reading somewhere that JE Engineering replace the valve seats with hardened ones so that you can run LPG without any issues.
yes I read that too but I've also read if you have a good clean base car ad its set up right there are people on here with 70k plus on lpg no issues Current stable:
Yea, sounds like you've been really unlucky. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
apparently if you remove the oil cap while idle running the engine should die if its working correctly - mine doesn't seem to - it would be good for someone with well running one to try and hear if this is indeed the case! Current stable:
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Why would it stop? Previous cars:
Just been out in the wind and rain. Engine note changes but doesn't stop! Previous cars:
im already to far in to do a compression test now.
Good question - the place mines at said that it would introduce unmetered air past the airflow meter and cause it to stop - if you have vsr the it can get in out the valves or something like that apparently... Thanks for that how many miles are you on? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
