Home > In Car Electronics (L322) > replacing the 2010-2012 head unit
Page 3 of 9 <123456789>
Danwilderspin
http://www.gazer.com/interface/intf/gazer-vi700a-gvif-gm
is this similar or the same? i got a quote and depending on exchange rate it was 700-800gbp Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #529222 26th Sep 2019 9:04pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Dan,
I think you may have found it!
But these guys are in the UK?
Was that quote fitted?
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #529231 26th Sep 2019 10:02pm
anything with the word "GVIF" normally refers to the 2002-2005 pre MOST systems....might be wrong though.. ... - .- -.
Post #529252 27th Sep 2019 6:59am
Danwilderspin
Hi Stan GVIF is the Sony protocol used by ford - bus is the pre ford protocol I believe.
But you raise a point do the 06+ and 10+ use the same gvif protocol? as there seems to be only one unit.
Email below is what I received:
Price would be £800.00
2 weeks delivery time
Kind Regards
Adil Khokhar
Director
CBS Automotive / Cambridge Car . Audio
Web: www.cbsautomotive.co.uk
Web: www.cambridgecar.audio
Tel: 01223 56 30 30
Address: Grange Farm, Horningsea, Cambridge, CB25 9JD Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #529262 27th Sep 2019 9:19am
Danwilderspin
£366.06 15% Off | Android navigation box for Lexus LS600h LS460 2005-2009 video interface box etc with carplay GVIF youtube waze yandex GPS
https://s.click.aliexpress.com/e/KI9d05Mnp
If anyone’s feeling brave this may be worth a punt. The toyota denso system is pretty much the same as ours (gvif)
On another website another module claims cross compatibility so just thinking this may be worth a punt
http://www.qdis.co.kr/product/interface.ph...mp;page=1# Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532999 2nd Nov 2019 10:45pm
En Vogue
Germany 2002 Range Rover Vogue Td6 Java Black
Found another option. Android Auto or Apple Carplay for the 2010MY is offered here :
https://www.naviplus.com.au/online-store/R...p157308347
Have contacted them and I have been told that it should not be a problem. Apparently Jaguar XKs and facelifted Range Rover Sports L320 have a similar system to ours?
https://www.facebook.com/pg/OldJaguarLive/...e_internal
Let me see if I can find out anything else about it.
No news regarding the Russian system yet? Instagram @l322passion
Post #535586 26th Nov 2019 11:08pm
Shesminetoo
Australia 2012 Range Rover Vogue 5.0 SC V8 Fuji White
Hi All,
Just a heads up. My 2011 V8SC with dual screen is in at Naviplus today and tomorrow to have this upgrade done. I am lucky that they are located only about 30min from my home. I wanted a solution that retained the standard functionality but can also run Apple carplay. I'll report back on the results when I get the car back if anyone is interested in this solution.
Regards
Frans
Post #543702 12th Feb 2020 6:57am
TrevCOSS
Very interested, hope it goes well. Will be interested if it’s carplay wireless as having to plug the phone in would be a pita
Post #543762 12th Feb 2020 7:19pm
Shesminetoo
They indicated that a bluetooth version is available but they are working through some issues with it. I preferred a wired solution however, given that with bluetooth it is always a hassle in the car when different people (Kids) want to play music at various times and we have to switch over BT connection all the time. Not a problem if you are the sole user of the vehicle. That and the fact that i'm expecting less hassles with a wired option. Also, the current BT connection via (Bovee) still remains so i can still have a master music connection always on, just not via Apple Carplay.
Post #543774 13th Feb 2020 2:56am
Shesminetoo
Well, I can report back that we achieved success. I can thoroughly recommend Tim and crew at Naviplus. The final product is very professional and works better than I expected. They were very helpful and friendly and communicated well throughout the process.
I dropped the car off on Wednesday and by Wednesday afternoon Tim called me to say the hardware is fitted and works, but not having worked with the gen 2 system especially with dual screen before, differences in the Canbus SW meant they had to spend more time trying to find a new way of activating carplay. On other versions it is activated by pressing and holding the Navigation button until it switches over. The fallback plan for mine was to install a little switch somewhere that i could push to switch over to carplay. Tim asked if he could have another day to play with it to see if they could find a way around the canbus issue without having to drill a hole for another switch. By Friday morning I was told the car is ready.
By pressing and holding the call cancel button on the steering wheel I now switch between old and new systems and the Carplay works flawlessly and boy does it ever bring the car into the 21st century! Using Siri works perfectly so no more frustrating navigation system. Spotify, aplle music all works great and everything looks so much more modern. If nothing else, I would recommend this as a safety feature too, as there is much less fiddling with the phone while driving.
There is a bluetooth option, but still in refinement and somewhat more expensive. As stated before i opted for the wired option just to keep things simple and reliable. The system response also seems faster with wired. They installed a dedicated USB port in the center cubby, so it doesn't look out of place or aftermarket at all.
Total cost was AUD$1350 but it included AUD$250 for fitting. in USD it would be about $740 before shipping and fitting. Not the cheapest option perhaps, but certainly one that preserves everything you want to preserve in the original setup whilst seamlessly bringing the car into the current decade.
Naviplus will ship as a kit and with their newfound knowledge re the Generation 2 system they ought to be able to provide lots of advice for DIY fitting.
I didn't take pictures because it looks like any other carplay! Happy to do a pic if you want. Hope this helps!
Regards
Frans
Post #543940 15th Feb 2020 1:47am
GGDR
Yes - pics please!!!!!
. Cheers, Greg
Post #543943 15th Feb 2020 6:56am
safehouse3238
United States 2009 Range Rover Supercharged 4.2 SC V8 Santorini Black
Has anyone tried the android version yet?
Post #545115 25th Feb 2020 1:00pm
Shesminetoo
Sorry no, i dont have an Android phone in the household, but when booting up it shows a choice between Carplay or Android. I suspect it would work just as well.
Post #545280 26th Feb 2020 10:30pm
safehouse3238
Oh interesting I'll have to give it a try then. Thanks
Post #545315 27th Feb 2020 10:15am
Weegie
It looks identical to the Navtool offering. If it is the same, I use my iPhone in the car. I tried to use a Samsung Tab but it didn't appear on the screen.
When you first get the unit (again if same as Navtool) you have to install the firmware which shows for either CarPlay or Android Auto. I am pretty sure if I had reloaded the firmware for Android Auto it would have worked with the Samsung.
I didn't try as it meant taking the unit out and connecting it to the internet which was too much of a faff as it was the iPhone I was using mainly.
Hope that helps. John
GAP iiD BT
Post #545318 27th Feb 2020 11:01am
