Home > Technical (L405) > How do the "cooled" seats work ? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2653 |
They run separate from the main aircon . Iirc they run off something called a peltier heater that’s actually in the base of the seat, the L322 did anyway . Once Craig is on a tea break he may come along with his legendary knowledge
18th Apr 2019 10:08am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 229 |
Very similar to the L322, description from Topix:
18th Apr 2019 10:47am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Strictly coffee for me sir Tea's drank by old people! |
19th Apr 2019 12:37am |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 51 |
Tried mine for the first time yesterday, remarkably impressed, I did think they were going to be a bit lame. |
21st Apr 2019 2:36pm |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
Thanks for all the replies , Defo a coffee drinker LOL |
25th Apr 2019 10:10am |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
If they’re similar to the l322, they’ve got air filters that need to be swapped out regularly |
15th Sep 2019 4:53am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
never heard of these filters for the cooled seats. the book doesn't mention them. Any idea where they are so they can be checked? |
15th Sep 2019 9:40am |
The filters were dropped for the L405 |
15th Sep 2019 1:52pm |
I looked up the part and the filter is still on there... Whether they give you access to it or not is another story but the peltier sort of needs an air filter. |
15th Sep 2019 2:48pm |
Just for technical clarity... I’m sat in a customers 14MY 405 and this has the filters present still sir... 👍 |
16th Sep 2019 10:37am |
Where are the filters situated and are they meant to changed or just cleaned as I can't find any reference to them on my "official" service checklist , Thanks |
16th Sep 2019 12:44pm |
There are two units in each seat, one in the seat back and one in the cushion. Yes the filters need to be changed out and this could very well be your issue. If your seat heating still works then the system likely isn't broken. The heating action relies on all aspects of the system working as it should, cooling the system can be damaged/faulted and still function. The peltier cell is the thing that provides the heating and cooling. When on one side of the peltier cell heats, the other side cools. When heating it moves air around closed loop in once direction through the system on one side of the cell to warm. When cool it is open loop drawing air over the cold side of the cell in another direction and out the perforated area of the seats. If the filters are clogged it won't be moving very much air over the cell which results in diminished cooling. When cooling it should be roughly 8 degrees F below the ambient.
16th Sep 2019 2:01pm |
Also possibly helpful to mention, if you have a capable diagnostic you can actually monitor how the cells are performing, there are several temp sensors throughout the system... If you live stream the temp sensors on the particular seat WITHOUT it running. All the temp sensors should read roughly ambient. If there is one temp sensor displaying some improbable temp the whole blower unit/peltier needs to be replaced. That or maybe the seat itself throws a code and disables itself (but not always) with no diagnostic if the heating works, you're likely in good shape. When heating the system makes use of all its temp sensors in an attempt to not set fire to the car |
16th Sep 2019 2:11pm |
Brad S1 : Thanks for all that , Getting the Autel out tomorrow when I get home . |
16th Sep 2019 3:41pm |
