![]() | Home > Technical (L322) > Splutter, jerk, judder restricted performance mystery SOLVED |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
My first thoughts would be fuel starvation for some reason ?.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi Greg , just on the IID tool ( which i think are great ) i had a similer issue with my 405 but i think my issue is specific to the 405 BUT the IID didn't record an error code for the first 10 times ( appox) it did it but then did record a code which helped me trace the issue. Sorry i can't help with the specific issue you have. 2015 4.4 AB
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Thanks Mike. Fuel - interesting and a good line of enquiry, thank you!
Thanks John! And Mike this is certainly in line with your first thought re fuel.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
fuel filter ? maybe water in there.. ... - .- -.
I was thinking very same thing Stan, plus ,any air leak into fuel filter / supply.
No problem Greg ,very annoying when you don't have a fault code to work from. I was amazed my iid tool didnt show a fault code as the hesitation, etc was very pronounced. Good luck with the fault finding |
back now mike |
Thanks Stan too, good idea.
Good question Greg, I don’t know the answer, but have been reading through WM this AM and this is only reference to engine judder that I can find.
thanks Mike! Haven't had time to browse the manual yet.
Hi Greg , it did , performance was reduced, less throttle response and less power. 2015 4.4 AB
I mean the juddering... Cheers, Greg
