Home > Maintenance & Mods (L322) > First Signs of Rust!!
Just spotted this today Big Cry :
(If you can't identify location, it is passenger side rear quarter panel, just above the mudflap.)
My FFRR is Apr 02, so an early one, guess I am leading the field on this one Laughing
Not had a chance to look inside the boot area and have a peer in-between all the gizmos (bike rack preventing boot access today), or to check for damp in that area, or if there is a mud trap underneath.
Yes Dan, I do have the air con on every now and then Smile .
Post #52553 2nd Mar 2011 2:39pm
On ALL the time Joe on ALL the time Laughing
Post #52555 2nd Mar 2011 2:42pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I have some similar bubbles under the plastic trim that surrounds the windows. unsure if I can get rid of them.
Like Gaz says get the air con on all the time. Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #52561 2nd Mar 2011 2:46pm
dan_uk_1984
You may joke - but you know it's true Cool
Check your rear wheel arches, where the door shuts, but on the oher side. These were never protected and the water/muck from road strips the paint right off Sad
Post #52563 2nd Mar 2011 2:49pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
air con all the time, whys that... Laughing
dont look good mate as its coming from behind so will be alot worse than suface rust from chipped paint... Sad 2004 black Vogue TD6
Post #52565 2nd Mar 2011 2:50pm
dan_uk_1984
I wonder if it's had a dodgey repair there in the past? The paint looks a bit un-even, it's not unheard of for damage to occur in the factory/delivery and be patched up prior to going on sale.
Post #52575 2nd Mar 2011 3:13pm
paneldamage
Mine had this when I bought it, plus some rust at the top where it meets the D post cover. My body shop mate stripped it back and found it was due to a poor quality repair at some point in its past.
I dont think it is double thickness/ seams here- on mine it was in good order behind. What is the other side like in the same spot?
Post #52619 2nd Mar 2011 10:21pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
is this the trim at the 'top' of the door (below the glass?)
if so i've got 'bubbling' underneath three of the windows
its basically a plastic/rubber sleeve over a metal 'core' - so moisture gets underneath and it rusts from the inside - appearing as bubbles
i am replacing all mine - cost £126 from Yeovil Land Rover (recommended on here for discount parts)
Post #52714 3rd Mar 2011 3:30pm
GregP
Thanks nick. I'll give them a call when replacing it. FFRR TD6 HSE
Post #52765 3rd Mar 2011 6:02pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I was thinking that the vast majority of RR panels were aluminium and so not easily rust prone ,so are the rear panels just 'standard' metal then? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #52840 3rd Mar 2011 11:39pm
dan_uk_1984
Not only are they metal - but they're steel. Thumbs Up
Post #52842 3rd Mar 2011 11:50pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
What is the Land Rover description of the trim below the glass as I would like to replace mine Wink
Post #57897 31st Mar 2011 6:00pm
L322 Pilot
On my 2002 L322 I have exactly the same rust spots on the nearside rear quater panel. I had it checked
by Guy Salmon Land Rover Coventry Body shop. The chap who did the assessment said he had not seen this before and without removing any paint guessed that it probably was due to a repair job.
I have had the car for three years and this rust has only recently appeared. Wheather or not you have the air con. on or off I doubt that it would have any influence in this area.
Post #60090 12th Apr 2011 6:45pm
Wash your mouth out! Of course the aircon being on is the answer to everything! Ask Dan. Lol
Post #60098 12th Apr 2011 7:52pm
Re: First Signs of Rust!!
The rust burst through at the weekend, so will have to see to it now .
Post #72184 12th Jul 2011 10:12pm
