Home > Technical (L322) > Front suspension bottom arm bushes and ball joints - FIXED
Page 4 of 5 <12345>
kbald
kbald wrote:
You could have it on its side in a vice with a plate or something holding the pour in place while it sets pretty easily I would think. Just a thought but could be a cheaper and easier option than poly bushing or replacing the whole arm. Alternatively maybe some tiger seal or equivelant in the voids could work as that is pretty thick and sticky as!
Haha I did say that. I meant the bushes not the arms.
Well done GDM Current 2007 TDV8 Vogue Buckingham Blue
Post #525199 18th Aug 2019 9:07am
GGDR
Nice one GDM.
Updates please once you get them on.
And especially desperate to hear what you think of the ride and road feel once they're in.
Thumbs Up Thumbs Up Thumbs Up
. Cheers, Greg
Post #525202 18th Aug 2019 9:28am
Nick591
Interesting. I had thought that the rather complicated shape of the rubber bush on the TCA was designed to allow some movement to cope with steering geometry through full lock and suspension height changes which are considerable on the FF if used off road. If a solid bush, even if made from rubber 'would do' why would LR not have done that? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #525212 18th Aug 2019 10:31am
GGDR
Nick, you've raised a few good points - I've been trying to get my head around the OE rubber design.
Now I'm suddenly less convinced this is the way to go....
You can buy new arms with the bushes pre-fitted as we all know and those Poly bushes are £75 a pair so price-wise there's not much in it.
Fitting (with new arms as opposed to pressing the bushes in & out) again not much in it.
.. Cheers, Greg
Post #525228 18th Aug 2019 11:28am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I've followed this thread from the start.
A few things I don't get.
Parts; polybushes are more expensive than complete replacement arms with bushes already fitted. £75 vs £40 +-
"At home" labour is vastly different than "garage" labour. You won't want to be paying a mechanic £50-£100/hour to be swearing and sweating over 'welded in' bushes.
To fit polybushes the arms need to be removed and then all sorts of effort and time is involved removing the old bushes and fitting the new bushes before refitting to the vehicle. Costing a whole chunk.
To fit complete new units, as above the arms need to be removed, but then here is the no brainer, new complete arms can then be directly bolted on. Job done, replacement from the arm off situation to a new arm on situation 15mins tops.
I've just done the whole of the front of my L322 with all new complete parts. The only sticking points were the famous bottom ball joints requiring the quick fix of removing the hub and then belting them with a long handled hammer against solid concrete. Probably saved more than a few hours banging away under the vehicle.
Replacing bushes in this manner was great and one of the only ways available before China was discovered by Internet Pioneers in the early 2000's.
Gone are my days of sitting in the gravel trying to burn bushes out of the bottom of a Series Landie and hoping that the rubber fire will remain local, before I could remove the leaf springs. Oh to be young again.
Cheers, Rich
Post #525302 18th Aug 2019 8:32pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I tried replacement TCAs about 3 years ago (along with radius arms, ball joints and ARB links) and they weren't the cheapest available. Just over a year later I was getting an advisory on the MOT for wear in the bushes, then a knocking from them, hence my decision to try the Powerflex bushes this time. The genuine LR TCAs might last a decent amount of time but they are well over £200 each.
Post #525314 18th Aug 2019 10:04pm
GraemeS
Australia
My Power-Flex bushes are now fitted. Tomorrow I'll get first impressions on bumps and ruts, fast gravel and sealed roads before embarking on a 5,000 km mostly on-road trip then shortly afterwards a 3,000 km trip with a reasonable percentage being outback tracks.
I couldn't budge the first bush in-situ using a bush-removal tool and an air impact wrench but both ball-joints separated easily with the nut protecting the end of the thread sitting on a jack and a few hard thumps on the arm with a small sledge-hammer. A 10-tonne press pushed-out the old bushes.
Post #525489 20th Aug 2019 4:16am
GraemeS
Australia
Almost immediately I decided that the bushes introduced a harshness that I'm not prepared to put up with so new normal bushes will be sourced ASAP. Vibrations from the stones in bitumen are felt through the steering wheel. I'm surprised that the manufacturer has persisted with the production of these for our vehicles as I doubt that anyone would be happy with the ride, Hence I will have to look forward to replacing bushes at every 2nd engine oil change unless the ones last fitted are subsequently shown to have been faulty.
Post #525622 21st Aug 2019 4:17am
GGDR
Thanks for letting us know Graeme shame your time and money was wasted
. Cheers, Greg
Post #525629 21st Aug 2019 7:17am
GGDR
GDM how have you got on?
. Cheers, Greg
Post #525630 21st Aug 2019 7:17am
GraemeS
Australia
I refitted the removed driver's side one inside out to use the good sides whilst I wait for a new set.
Post #525657 21st Aug 2019 10:46am
GDM
Fitted one side yesterday evening, was out with the family this evening, so will do the other side tomorrow after work.
Glen.
Post #525803 22nd Aug 2019 12:20am
GDM
Changed the arm on the other side yesterday evening and took the car for a run. The ride doesn't seem to be too bad at all. It felt a little less compliant on the smaller, rougher roads, but once on A and B roads it felt fine. It has 20" stormer wheels with 275/45 tyres, so I guess the sidewalls are fairly stiff anyway. The steering did feel a lot more precise at speed. I think the old bushes were moving about over bumps and causing the steering to wander a bit. The O/S bush was quite soft and the N/S one already had a tear in it.
Getting two new front tyres fitted and a 4 wheel alignment in the morning.
Post #525942 23rd Aug 2019 5:25pm
GDM
New tyres fitted yesterday but track rod ends seized, so they weren’t able to do the tracking. Looks like I need new inner rods and rod ends. Also the rear adjusters were seized, so need to free them off, or fit new bolts and bushes. Going to concentrate on the front first.
Post #526109 25th Aug 2019 9:28pm
GDM
Post #526111 25th Aug 2019 9:48pm
Page 4 of 5 <12345>
