Home > Technical (L322) > Front suspension bottom arm bushes and ball joints - FIXED
Page 2 of 5 <12345>
roblane65
Did upper and lower front arms + ball joints on mine a couple months back ( on the drive ) all parts from maltings 4 x 4
not to dad a job but some times you could do with three hands only advice make sure you have 4' or 5' bar for levering the arms or get a mate to give you a hand. The only thing I've poly bushed is the anti roll bars I think they are to harsh for the road and will spoil the ride . as for the after market bushes time will tell .Its a heavy beast so the front suspension must take some serious hammer. Range rover 4.2 SC 06MY.
Post #524458 11th Aug 2019 3:06pm
AJGalaxy2012
Is it safe to assume these are knackered?
 BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #524473 11th Aug 2019 7:27pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Most definitely and your front tyres will be getting scrubbed out too.
Post #524486 11th Aug 2019 9:41pm
AJGalaxy2012
Thanks for confirming, I was pretty sure when I looked in there LOL BMW i3 Electric Car
Post #524488 11th Aug 2019 9:42pm
GDM
AJGalaxy2012 wrote:
+1 also, where do you get your bushes from?
Unfortunately the weather messed up my plans for getting them done this weekend. Will report back as soon as they are done.
Here is the E-bay link to where I got them from.
https://www.ebay.co.uk/itm/POWERFLEX-FRONT...2749.l2649
Post #524489 11th Aug 2019 9:44pm
AJGalaxy2012
Thanks for the link and I look forward to the update. BMW i3 Electric Car
Post #524490 11th Aug 2019 9:49pm
GDM
Does anyone have a used pair of the TCAs that they want to sell? I could fit my Powerflex bushes to them and then just swap the arms over. Would save the car being off the road for so long and as there are no ball joints on the arms, nothing else to wear.
Post #524582 12th Aug 2019 11:59pm
GGDR
They look easy to fit, am I right in thinking no press needed ?
. Cheers, Greg
Post #524597 13th Aug 2019 10:49am
GDM
Yes, dead easy to fit, the bush is split with a stainless sleeve that goes through both parts. It will be getting the old ones out that will be the main issue, hence my request for some used arms. Annoyingly, I didn't keep my old ones from a few years back.
Post #524702 13th Aug 2019 9:25pm
GGDR
I saw /read somebody 'collapsed' the old one out.
Went a bit like this:
The steel outer bush lips out so get a chisel on it, and bang the ring inwards to create an inwards kink.
Then hopefully loosening it enough to slip it out.
The more I think about it, the more I think I'll do mine this way with those split bushes.
No need for a press if all goes well...?
. Cheers, Greg
Post #524707 13th Aug 2019 9:44pm
nosmo
Frexan wrote:
Go for nr 3! just did this on my L322. Complete kit for both side was cheap (order from UK), and it's an easy job for your local mechanic. Smile
Where did you order from Frexan ? 2003 4.4 V8 Vogue
Post #524795 14th Aug 2019 3:49pm
AJGalaxy2012
Well I chickened out and took my car to Lovells Land Rover today, all 4 lower arms replaced and the result ? still lnock, not as bad but knocking.
Back to the drawing board. BMW i3 Electric Car
Post #524833 14th Aug 2019 8:18pm
GDM
Have you checked the ARB links?
Post #524849 14th Aug 2019 9:37pm
AJGalaxy2012
Strangely that was my first thought, one side is new after doing my offside air suspension bag, the otherside isnt. I drove round for a while with one link missing and there was no knocking, when I fitted the link the knocking was very pronounced. Other symptoms, if I go round a corner left or right theres no knocking (I assume if it was the drop links thats because it's under tension.
I may just try a pair of drop links and see if it cures it, I was sure when I saw that bush, that was my problem, they also replace a ball joint because one was bad. BMW i3 Electric Car
Post #524852 14th Aug 2019 9:44pm
GGDR
Did they do the ball joint cassette John?
EDIT clicked too soon and saw the last bit you wrote Embarassed Cheers, Greg
Post #524862 14th Aug 2019 10:44pm
Page 2 of 5 <12345>
