![]() | Home > Maintenance & Mods (L322) > TDV8 turbo intake pipe loose |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 ![]() ![]() ![]() |
Seems very loose. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
I applied some vaseline to mine to improve the seal. It was snug though already. The rubber flange seemed to grip well. Otherwise it would drag in a load of dirty air or water... __
Did it ever cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
No. I did a smoke test and no leaks after I'd rebuild and refitted the engine.
So if that’s happened to mine would you say it would cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Whats the fault code you are getting? __
That's highly likely to be your inlet manifold.
I had a smoke test done last week and the inlet manifold was fine.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 ![]() ![]() |
How hot was the engine when you had your smoke test?
It was up to temperature as I’d driven to the garage just before the smoke test. The only leak was the hole in the air tube which I’ve replaced. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Mine would not show unless it was operating temperature and after a run.
I think this car came with a multitude of problems which is why the previous owner sold it. He knew exactly what he was doing when he sold it to me.
