Home > Maintenance & Mods (L322) > Calling engineers: how do I avoid drilling my engine block? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Posted here https://www.fullfatrr.com/forum/post520114.html#520114
30th Jun 2019 10:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
my only thought is engine heat...screwiing in a pipe would be better job than some kind of adhesive... ... - .- -.
30th Jun 2019 10:49am |
it probably is greg
30th Jun 2019 11:46am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
I think when they put the bung in it has a concave shape so then apply some bonding and then hit the centre which expands the plug into position? |
30th Jun 2019 1:08pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
I like your idea GGDR, it would make the modification a lot easier, but......if it was that simple, wouldn't JLR make that the official modification instead of drilling and all the associated swarf worries?
30th Jun 2019 6:03pm |
Well maybe not. If Ford were found to be contractually responsible, then surely the fix is belt and braces, with Ford picking up the bill? (Or their insurers). Making a quick fix not too relevant. Just my theory.
30th Jun 2019 6:50pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
The simple answer is yes, you can get suitably bonding and sealing agents. Speak to a 3m rep or similar.
30th Jun 2019 7:02pm |
Here's the JLR modification fitting
30th Jun 2019 7:52pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Greg,
1st Jul 2019 7:21am |
