Home > Maintenance & Mods (L322) > IID TOOL says Cyl 5 is at back of engine and not 6!! |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
3 6
26th Jun 2019 2:22pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Hi Dan it’s a TD6 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
26th Jun 2019 2:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
does this help [from the WM]
26th Jun 2019 2:43pm |
As Stan says
26th Jun 2019 2:44pm |
This is my point why is my IID tool saying that the cylinder at back of engine is Cyl 5 then when it is Cyl 6 is it a possible wiring loom fault that I have Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
26th Jun 2019 2:56pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
On my Mercedes S Class I was a bit confused as well it turned it was the firing order.
26th Jun 2019 4:02pm |
Yeah I understand that the firing orders etc but surely it would have them all mixed up then it just seems very odd that it is seeing CYL 6 as CYL 5 and when I pull all the connections to the injectors and leave CYL 6 purposely connected I still get a fault code that CYL 6 has been disconnected!! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
26th Jun 2019 4:15pm |
Just had this reply from Gap just to confuse matters!!
26th Jun 2019 4:43pm |
So basically as Pat says the IID is not set up correctly as per Land Rover Cylinder sequence so how can you possibly use this tool to diagnose a specific problem if it is not set up to read the Cylinders in the correct order! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
26th Jun 2019 4:51pm |
