Home > Maintenance & Mods (L322) > IID TOOL says Cyl 5 is at back of engine and not 6!!
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys a mad one here I’m still having issues possible thinking I have a bad injector and on disconnecting each injector from loom except for cyl 6 I still got fault code for cyl 6 being disconnected and on live values for fuel consumption when I disconnect CYL 5 it gives me a high read for CYL 6. I am right in thinking the Cylinders are as follows from front of engine is Cyl 1 and back if engine is 6.
cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #519749 26th Jun 2019 2:13pm
duckworthparts
Site Sponsor
2 5
1 4
like so I believe You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #519752 26th Jun 2019 2:22pm
jaysta10k
Hi Dan it’s a TD6 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #519755 26th Jun 2019 2:36pm
does this help [from the WM]
Post #519757 26th Jun 2019 2:43pm
duckworthparts
Site Sponsor
As Stan says
Front 1 2 3 4 5 6 Rear You can paypal direct using - www.paypal.me/duckworthparts
Post #519758 26th Jun 2019 2:44pm
jaysta10k
This is my point why is my IID tool saying that the cylinder at back of engine is Cyl 5 then when it is Cyl 6 is it a possible wiring loom fault that I have Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #519761 26th Jun 2019 2:56pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
On my Mercedes S Class I was a bit confused as well it turned it was the firing order.
It physically is number 6 cylinder but number 5 in firing order - well at least it was for my merc.... Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #519769 26th Jun 2019 4:02pm
jaysta10k
Yeah I understand that the firing orders etc but surely it would have them all mixed up then it just seems very odd that it is seeing CYL 6 as CYL 5 and when I pull all the connections to the injectors and leave CYL 6 purposely connected I still get a fault code that CYL 6 has been disconnected!! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #519770 26th Jun 2019 4:15pm
jaysta10k
Just had this reply from Gap just to confuse matters!!
Previous Cars
BMW M3 Carbon Black
Post #519774 26th Jun 2019 4:43pm
jaysta10k
So basically as Pat says the IID is not set up correctly as per Land Rover Cylinder sequence so how can you possibly use this tool to diagnose a specific problem if it is not set up to read the Cylinders in the correct order! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #519776 26th Jun 2019 4:51pm
