![]() | Home > Maintenance & Mods (L322) > A fresh look required |
biggirly1 Member Since: 21 Nov 2017 Location: Bicester Posts: 12 ![]() ![]() ![]() |
Any one point in the correct direction ?
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
I think you're on the right track -- have a look at each of those U04XXXX codes on good old google, it should lead somewhere, a lot of the other stuff just looks normal to me Current: 2011 FFRR Vogue SE 4.4 TDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
clear all faults and check again in a few days... |
Stan! the car doesn't start!
Suggest also, before clearing the faults, look at each one for the date they occurred (not the date you read them). Would guess that most are quite old, the majority being the sort that have absolutely no impact on operation or performance, and will re-occur again and again. The more recent ones will indicate where the problem may lie.
Thanks everyone for your help much appreciated
Done a bit today and learned a lot
I was sold that B1B01-87 (2C) Key transponder is a common fault code and not to worry about it ( You can't reprogram key with IID tool with out starting the engine so a bit chicken and egg
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Hmmm. Good point. Mine's a diesel so not so familiar with these gremlins. I'm moving to Bicester soon and am there quite often now. I could pop in. Two heads might be better than one? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
It is a 3,6 diesel like yours
Ok found problem
Glad you found that |
yes mate |
