Home > Maintenance & Mods (L322) > A fresh look required
biggirly1
United Kingdom 2007 Range Rover Vogue SE TDV8 Zambezi Silver
Any one point in the correct direction ?
reported fault
Model L322 - Range Rover 2007
Vehicle scanned on 11 Jun 2019 13:51:19
IIDControl 2.9.4.5 Android - IIDTool Pro V3.0 B3962
AAM-Audio Amplifier
B1A02-13 (2F) Speaker 2 circuit - General electrical failure - circuit open
( on 11-06-2019 13:48:00 at 106498 mi )
B1A01-13 (2F) Speaker 1 circuit - General electrical failure - circuit open
ATCM-Terrain Response
U0401-94 (2E) Invalid data received from engine control module/powertrain control module - Component failure - unexpected operation
( on 11-06-2019 12:59:08 at 106498 mi )
U0402-94 (2F) Invalid data received from transmission control module - Component failure - unexpected operation
( on 11-06-2019 12:59:06 at 106498 mi )
U0416-94 (2F) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
U0403-94 (2E) Invalid data received from transfer case control module - Component failure - unexpected operation
HVAC-Heat / Cool
0x3 Left seat temperature sensor fault
0x4 Right seat temperature sensor fault
LCM-Light Control
0x5B Washer fluid level fault
PBM-Parking Brake
U0401-00 (2B) Invalid data received from engine control module/powertrain control module
( on 11-06-2019 12:52:44 at 106498 mi )
TMC-Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
VDM-Vehicle Dynamic
U0401-68 (2B) Invalid data received from engine control module/powertrain control module - Algorithm based failure - event information
( on 11-06-2019 12:55:18 at 106498 mi )
VIM-Immobilizer
B1B01-87 (2C) Key transponder - Bus signal/message failure - missing a message
( on 11-06-2019 13:02:33 at 106498 mi )
it turns over and attempts to fire but non start, done normal things it smokes on turning over etc
I'm sure it's something to do with ATCM-Terrain Response or I'm stupid
So what am I missing? Range Rover
L322 TD6, TDV8
P38 Overfinch
Range Rover Classic 3.5 tuned it
3,5 convereted to 3.9JE
std 3,9 converted to 4.2 JE
Land Rover 110 V8 converted to Mazda 3.5 td
Land Rover 130 V8 converted to GM TD6.5
Discovery 200, 300, TD5, mk 3 2.7tdv6
Nissan D21
Ford Cortina Mk2 1600E converted to 3.1 V6 overdrive gearbox and capri 3.0 axle
Post #518071 11th Jun 2019 4:17pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I think you're on the right track -- have a look at each of those U04XXXX codes on good old google, it should lead somewhere, a lot of the other stuff just looks normal to me Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #518073 11th Jun 2019 4:21pm
clear all faults and check again in a few days...
Post #518074 11th Jun 2019 4:28pm
Bushy30
Stan! the car doesn't start!
OK -- a quick search on FFRR forums led me to someone with a similar issue -- that manifested in the end as a non starting issue
It was the crankshaft position sensor
Can you read the live values when attempting to start -- do you see the CSPS values change?
https://www.fullfatrr.com/forum/topic41392.html Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #518075 11th Jun 2019 4:37pm
Suggest also, before clearing the faults, look at each one for the date they occurred (not the date you read them). Would guess that most are quite old, the majority being the sort that have absolutely no impact on operation or performance, and will re-occur again and again. The more recent ones will indicate where the problem may lie.
However Terrain Response issues shouldn't necessarily stop the car from starting, could it be fuel delivery related (not so many sensors to help you there) .
Post #518076 11th Jun 2019 4:37pm
biggirly1
Thanks everyone for your help much appreciated
I will double check the output from crank and cam shaft sensor tomorrow and let you have results
Fuel system is 100% perfect that has been all checked out
The fact that the system says it's a information issue makes me think it could be any thing and I googled the sh&t out of the codes looking and testing that's why I put it out there Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518090 11th Jun 2019 7:34pm
biggirly1
Done a bit today and learned a lot
so far today down to these
Vehicle scanned on 12 Jun 2019 10:52:24
AAM-Audio Amplifier
( at 106498 mi )
*Test Failed
*Test Failed This Monitoring Cycle
*Confirmed
*Test Failed Since Last Clear
( on 12-06-2019 10:40:05 at 106498 mi )
*Test Failed
*Confirmed
HVAC-Heat / Cool
RLM-Suspension
U0416-86 (26) Invalid data received from vehicle dynamics control module - Bus signal/message failure - signal is invalid
( on 12-06-2019 10:05:40 at 106498 mi )
*Pending
TMC-Traffic Message
*Test Failed
*Confirmed
VIM-Immobilizer
( on 12-06-2019 10:46:03 at 106498 mi )
*Confirmed
and you couldn't write a story like this, It still won't start Rolling with laughter
Checked cam sensor all ok so crank sensor next but that will have to wait till tomorrow Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518175 12th Jun 2019 12:49pm
Nick591
If the last code involves the immobiliser wouldn't that be a prime suspect? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #518262 12th Jun 2019 9:29pm
biggirly1
I was sold that B1B01-87 (2C) Key transponder is a common fault code and not to worry about it ( You can't reprogram key with IID tool with out starting the engine so a bit chicken and egg
Also checked crank sensor and it,s fine.
Well it's proving to be little annoying Rolling with laughter Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518355 13th Jun 2019 4:41pm
Nick591
Hmmm. Good point. Mine's a diesel so not so familiar with these gremlins. I'm moving to Bicester soon and am there quite often now. I could pop in. Two heads might be better than one? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #518378 13th Jun 2019 7:30pm
biggirly1
It is a 3,6 diesel like yours
I'm a mechanic buy trade and as such work on a fair number of land rovers but this is my own and I of-course a complete nightmare. This car has a story and I have never heard it run, purchased it from a mate with turbos gone and low compression 2 cylinders. I am anally retentive about doing things write so every thing on this engine is 100% now
Never had a vehicle I couldn't fix and this will turn out to be something stupid Rolling with laughter
Tomorrow I'll learn s bit more
I'm about 5 miles out of Bicester but always happy to make you a tea or coffee and put the world back in order Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518404 13th Jun 2019 9:13pm
biggirly1
Ok found problem
I installed the crankshaft pickup ring with a tdv6 2.7 after being told by company who make them that the v8 tool is the same. My fault should have checked it my self, new tool tool and ring ordered from land rover Deep Joy
Looking forward to seeing company rep next time he drops in Rolling with laughter I think the conversation will be interesting Evil or Very Mad Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518465 14th Jun 2019 1:30pm
Bushy30
Glad you found that Wink
Hope it's an open invitation.......... coffee sounds great !
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #518474 14th Jun 2019 2:29pm
biggirly1
yes mate Thumbs Up Range Rover
L322 TD6, TDV8
P38 Overfinch
Nissan D21
Post #518513 14th Jun 2019 6:50pm
