Home > Maintenance & Mods (L322) > A fresh look required |
biggirly1 Member Since: 21 Nov 2017 Location: Bicester Posts: 12 |
Any one point in the correct direction ?
11th Jun 2019 4:17pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
I think you're on the right track -- have a look at each of those U04XXXX codes on good old google, it should lead somewhere, a lot of the other stuff just looks normal to me Current: 2011 FFRR Vogue SE 4.4 TDV8
11th Jun 2019 4:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
clear all faults and check again in a few days... |
11th Jun 2019 4:28pm |
Stan! the car doesn't start!
11th Jun 2019 4:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Suggest also, before clearing the faults, look at each one for the date they occurred (not the date you read them). Would guess that most are quite old, the majority being the sort that have absolutely no impact on operation or performance, and will re-occur again and again. The more recent ones will indicate where the problem may lie.
Thanks everyone for your help much appreciated
11th Jun 2019 7:34pm |
Done a bit today and learned a lot
12th Jun 2019 12:49pm |
I was sold that B1B01-87 (2C) Key transponder is a common fault code and not to worry about it ( You can't reprogram key with IID tool with out starting the engine so a bit chicken and egg
13th Jun 2019 4:41pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Hmmm. Good point. Mine's a diesel so not so familiar with these gremlins. I'm moving to Bicester soon and am there quite often now. I could pop in. Two heads might be better than one? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
13th Jun 2019 7:30pm |
It is a 3,6 diesel like yours
13th Jun 2019 9:13pm |
Ok found problem
14th Jun 2019 1:30pm |
Glad you found that
14th Jun 2019 2:29pm |
yes mate Range Rover
14th Jun 2019 6:50pm |
