Home > Maintenance & Mods (L322) > Front brake callipers
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Anyone know what the correct colour is for the front callipers on a 2011 MY L322 TdV8 please? Just bought what I'm hoping is a nice Vogue in Bonatti Grey with black leather and piano black woodwork, it's obviously been looked after by it's 3 previous owners, very little rust on the wheel arch lips inside the rear door area, easily fixable and the last owner (given it looks no more than a couple of years old) had a Witter towbar fitted and it doesn't look as if its ever been used (tow ball still grey steel with no grease in evidence). Time will tell! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #517765 8th Jun 2019 10:26am
Baltic Blue
They are cast aluminium alloy, not coloured from factory.
Just a tip, the pad retaining pins are a common problem when they corrode and seize if not regularly removed and cleaned.
Post #517767 8th Jun 2019 10:39am
rvbush
Cheers Mike, I'll just clean them up then. Thanks for the tip re. the retaining pins, the supplying dealer just fitted new front pads so they should be ok for a bit, I'll do them when I clean up the callipers.
Roy Drives:
Post #517771 8th Jun 2019 11:25am
DrRob
Check its had the oil cooler gasket done. Most of them need doing at some time before 90K Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517776 8th Jun 2019 12:23pm
nearlee
Wales
Hope it's not bonatti grey, as it was discontinued in 2005.
And you could always bling the calipers a bit Whistle Remember:- amateurs built the ark
Proffesionals built the titanic
Post #517777 8th Jun 2019 12:45pm
Yours will be Stornaway Grey sir...
The SC's of the same era have gloss black Brembo callipers if that helps?
Post #517784 8th Jun 2019 1:34pm
nino_nino
just clean them well and coat with some NANO coating and they will stay clean for a long time. Thumbs Up
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #517798 8th Jun 2019 3:32pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
where does one get the said nano coating? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #517805 8th Jun 2019 5:12pm
nino_nino
I use this=
https://www.aliexpress.com/item/Free-deliv...4c4dKixU0P 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #517808 8th Jun 2019 5:21pm
rvbush
Many thanks for all the helpful responses. It’s had the oil cooler replaced less than 500 miles ago and at the same time had the main turbo replaced. Also, quite right, it’s Stornaway. Thanks again to all. Drives:
Post #517810 8th Jun 2019 5:30pm
