![]() | Home > Maintenance & Mods (L322) > Front brake callipers |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
They are cast aluminium alloy, not coloured from factory.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Cheers Mike, I'll just clean them up then. Thanks for the tip re. the retaining pins, the supplying dealer just fitted new front pads so they should be ok for a bit, I'll do them when I clean up the callipers.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Check its had the oil cooler gasket done. Most of them need doing at some time before 90K Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yours will be Stornaway Grey sir...
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
just clean them well and coat with some NANO coating and they will stay clean for a long time. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
where does one get the said nano coating? BMW i3 Electric Car
I use this=
Many thanks for all the helpful responses. It’s had the oil cooler replaced less than 500 miles ago and at the same time had the main turbo replaced. Also, quite right, it’s Stornaway. Thanks again to all. Drives:
