Home > Maintenance & Mods (L322) > Rear Tailgate strap rust
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
My tailgate straps are showing rust (god knows how bad it is under the rubber) I have seen some threads previously about replacing them with the later gas arm thingees.
Is that the only option? If so, please can I get some hints and tips. Also, how do I remove the rust stains from paint work as shown in the picture below? (This is on the left hand side.
Could replace with another strap but wondering if damper would be better. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #517119 1st Jun 2019 1:02pm
mjdronfield
I don’t think the damper supports anything, just slows it down opening, so you will still need straps, plus there is only a single damper used, just on the right side, when it’s fitted at the factory.
I’d just replace with new ones....maybe T Cut on the paint?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #517121 1st Jun 2019 1:28pm
mjdronfield
I’m not aware there is an upgrade for the straps? Have I missed something?
Just realised you already have the damper fitted.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #517122 1st Jun 2019 1:30pm
scotcruz
Think they come standard on 2011 MY. The wee strut is on the right side lower tailgate.
The mod strap has a fitting on the top for the strut and you drill two holes at the bottom to attach it to the bracket.
Below is the link:
https://www.fullfatrr.com/forum/topic12431.html Current:
Past:
Post #517123 1st Jun 2019 1:36pm
rjff
Replace the straps, they will fail if rusting. See the various threads on here (Stan got dumped on the deck when his failed).
If you have not got a damper but are fitting one, make sure you get the correct straps. Cheers
Richard
Gap IIDBT
Post #517125 1st Jun 2019 1:42pm
scotcruz
Cheers Richard, I was wondering if there was any greater benefit of adding the strut other than the booth not banging hard and coming down slowly. Not really keen on drilling holes, especially after some folk report the screws went loose after a short while. Current:
Past:
Post #517126 1st Jun 2019 1:49pm
rjff
Hi Scot
Mine came with the damper fitted, not sure if I'd fit one otherwise. Cheers
Richard
Gap IIDBT
Post #517130 1st Jun 2019 2:06pm
Baltic Blue
I have had both, but was always happy with earlier Td6 with no strut.
I wouldn’t bother retro fitting.
Post #517133 1st Jun 2019 2:13pm
Retro fitted on two FFRR's - just enjoyed the damped drop of the tailgate. No issues with screws coming loose, I tapped the holes I made so the set screws (bolts) are held nicely in place. Otherwise make smaller holes and use self tapping screws .
Post #517135 1st Jun 2019 2:17pm
Weegie
Replaced both straps last month. Didn't bother with the damper. Don't really see the need for it. Just lower it by hand. One of the new ones had a nipple on it for the damper.
Re the rust, a mild solution of oxalic acid will remove surface rust like that. John
GAP iiD BT-Sold
Post #517138 1st Jun 2019 2:50pm
scotcruz
Cheers folks... looks like I will skip the damper.
How much was it for the pair of new straps Weegie? Current:
Past:
Post #517141 1st Jun 2019 3:12pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
https://www.fullfatrr.com/forum/topic48870...ate+straps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #517143 1st Jun 2019 3:25pm
andygts
Mine were seized when I first bought it years ago, when removed the cable was fine and the crimp, it was just the bush that spins that had rusted and from memory theres some plastic mixed in somewhere.
I applied some heat to free them off then covered them in grease and refitted with the rubber caps back over. They have been fine ever since and the lower tailgate can go for weeks without being dropped. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #517151 1st Jun 2019 5:06pm
Weegie
As per Bushy above. Thumbs Up John
GAP iiD BT-Sold
Post #517153 1st Jun 2019 5:21pm
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
DON'T buy the cheaper cables, the covering cracks and splits and cables rust for fun in 5 mins, even though I'd dunked em in grease! I'll be replacing em AGAIN soon before they snap but with original parts! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #517383 4th Jun 2019 10:28am
