Home > General > Steering column motor failure
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Got my first problem with my SC today. Got out of the car and the steering column just dropped! The steering wheel adjust no longer works going up or down. Left and right is fine. I can still hear the motor when trying to adjust it up and down. It's like it has disconnected from the motor. The column also doesn't lock into a position so it freely moves up and down. Hopefully should be covered under warranty after reading that most of the steering is covered. But just in case it ain't any ideas on cost so I can prepare myself or if this has happened to anybody elses ffrr. Easy or hard job
I don't like it when its broken Sad
cheers
Post #51234 21st Feb 2011 8:50pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I had mine replaced under warranty a few weeks ago. Mine would go in and out but not up and down. They told me it cost them nearly �700ish Shocked to replace the whole thing.
Hopefully you'll get it sorted under warranty FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #51237 21st Feb 2011 8:53pm
daveo
hi, its the plastic clip on the motor, it has gone on my one but the in and out, there a few post on how to repair it as you cant buy the plastic bit on its own come attached to the motor...not a hard repair and is done with cable ties but can be quite tight... V8 facelift Range Rover Autobiography 22" wheels.
Post #51239 21st Feb 2011 8:55pm
Ludzy
�700 Shocked
I hope it's covered. What is the actual part?
EDIT
Just realised I said left and right works. I ment in and out but I assume you all got that.
Post #51255 21st Feb 2011 9:55pm
daveo
this was a recall in the usa but never over here, the worse thing is you cant buy that silly little bit of plastic that snaps, Shocked WARNING if your steering sqeeks when going in/out or up/down then grease it...
http://www.fullfatrr.com/forum/topic4144.h...ring+colum V8 facelift Range Rover Autobiography 22" wheels.
Post #51261 21st Feb 2011 10:24pm
Ludzy
Well I ain't paying mega bucks to get it fixed. It's at an indy so I may just ask them to cable tie it!
It a pain in the rear when things go wrong.
Post #51262 21st Feb 2011 10:35pm
daveo
sorry, they wont do that for sure, will class it as unsafe.. you are going to need to jump up and down and start shouting that it needs to be done under warranty, how long have you had the car V8 facelift Range Rover Autobiography 22" wheels.
Post #51269 21st Feb 2011 11:06pm
Ludzy
Just over 3 months. Have extended cover for 12 months. It should be covered from the list of things covered. Haven't got the booklet on me so can't remember exact list of things.
Post #51275 21st Feb 2011 11:25pm
GregP
sounds like it should be covered.
I think they intially tried to repair mine, but had no luck. It was bust when I bought it but was clueless with Range Rover so only picked up on the problem after a few weeks of ownership. Was good they fixed it. FFRR TD6 HSE
Post #51277 21st Feb 2011 11:48pm
Ludzy
It would have to be the only part of the car they doesn't get used. Dont think me o the wife have ever actually moved the wheel as we both use the same seat and wheel settings. Hopefully should hear later today what the problem is.
Cheers
Post #51308 22nd Feb 2011 9:17am
Ludzy
So today the garage rings me to say that I need a new steering column. Near on �950!!!! Shocked
Rang warranty company and was told that the steering column is covered unless it broke due to wear. Appearently it's some kind on Metal plate thats broke but that can't be bought separately so new column it is. Left garage to confirm details with the warranty company etc. ... Haven't heard anything since so I assume it's fine and covered. Fingers crossed
Post #51629 23rd Feb 2011 8:51pm
GregP
sounds identical to the problem I had. Lets hope they fix it under warranty. FFRR TD6 HSE
Post #51632 23rd Feb 2011 9:43pm
daveo
fingers crossed the warranty pays, if they do, ask for the old column back after the repair and take it away with you...dont let them have it... V8 facelift Range Rover Autobiography 22" wheels.
Post #51646 23rd Feb 2011 10:55pm
Ludzy
That figure of �950 is an exchange for the old column. Was told it would be about �1600 for a new unit. Went to the garage first found out the prob then contacted the warranty people to make a claim.
Hopefully no news is good news as I'm sure the garage will ring me if the warranty company don't wanna pay up as there know I ain't happy about this big pay out.
Post #51652 23rd Feb 2011 11:25pm
Shaun the Sheep
England 2007 Range Rover Vogue TDV8 Stornoway Grey
I got into mind and turned tnhis ignition on and the wheel nealy chopped my legs off, was fine as soon as I turned ignition off, but as soon as I turned if off, down it went again and again
Just had mine done under warrant, and apparently whilst they do it, they are under instructuions from Land Rover to replace the seat module at the same time, please dont ask me why, it's just what I was told
Post #51668 24th Feb 2011 3:25am
