![]() | Home > General > Steering column motor failure |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
I had mine replaced under warranty a few weeks ago. Mine would go in and out but not up and down. They told me it cost them nearly £700ish |
hi, its the plastic clip on the motor, it has gone on my one but the in and out, there a few post on how to repair it as you cant buy the plastic bit on its own come attached to the motor...not a hard repair and is done with cable ties but can be quite tight... V8 facelift Range Rover Autobiography 22" wheels.
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 ![]() ![]() ![]() |
£700 |
this was a recall in the usa but never over here, the worse thing is you cant buy that silly little bit of plastic that snaps, |
Well I ain't paying mega bucks to get it fixed. It's at an indy so I may just ask them to cable tie it!
sorry, they wont do that for sure, will class it as unsafe.. you are going to need to jump up and down and start shouting that it needs to be done under warranty, how long have you had the car V8 facelift Range Rover Autobiography 22" wheels.
Just over 3 months. Have extended cover for 12 months. It should be covered from the list of things covered. Haven't got the booklet on me so can't remember exact list of things. |
sounds like it should be covered.
It would have to be the only part of the car they doesn't get used. Dont think me o the wife have ever actually moved the wheel as we both use the same seat and wheel settings. Hopefully should hear later today what the problem is.
So today the garage rings me to say that I need a new steering column. Near on £950!!!! |
sounds identical to the problem I had. Lets hope they fix it under warranty. FFRR TD6 HSE
fingers crossed the warranty pays, if they do, ask for the old column back after the repair and take it away with you...dont let them have it... V8 facelift Range Rover Autobiography 22" wheels.
That figure of £950 is an exchange for the old column. Was told it would be about £1600 for a new unit. Went to the garage first found out the prob then contacted the warranty people to make a claim.
Shaun the Sheep Member Since: 21 Mar 2010 Location: Bolton, Lancashire Posts: 48 ![]() ![]() ![]() |
I got into mind and turned tnhis ignition on and the wheel nealy chopped my legs off, was fine as soon as I turned ignition off, but as soon as I turned if off, down it went again and again
