Home > Technical (L322) > Reversing sensors on when towing |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
So I’ve just hooked up the tintent to get it cleaned after the winter.
12th May 2019 7:19pm |
It’s a factory fitted Westfalia though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
13th May 2019 6:08am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
Maybe to simple, but I am, if the plug is not really pushed in or if the cable of the trailer has a problem the sensors keep on beeping. Does it show the little trailer on the dash when plugged in? |
13th May 2019 11:14am |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 |
The air suspension should also be disabled (orange light on switch) when a trailer is sensed as plugged in
13th May 2019 11:33am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2480 |
The air suspension on MY07 onwards (Terrain Response is fitted) is not disabled when a trailer is detected although automatic selection of off-road height is disabled if rock-crawl is selected. |
13th May 2019 11:59am |
No my air suspension is not disabled when a trailer is plugged in. |
13th May 2019 12:48pm |
