Home > Technical (L322) > 2011 tdv8 AB 13 pin towing electrics
MisterT
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Hi All
First post on here, recently acquired my 2011 TDV8 Autobiography and loving it. It's my second FFRR having had a P38 years ago.
Car is fitted with factory fit 13 pin electrics and Westfalia detachable hitch, today I hitched up the caravan to tow to South Wales and surprisingly there was no power to the caravan for the fridge or battery charging. All of the lights and Alko stability device are fine, it seems to be only the supply that would come through a split charge relay that is missing.
Questions;
Would a split relay system usually be fitted as part of a factory fit 13 pin electrics?
Is there a fuse I can check for any split relay installation, where would it be located?
Are there different 13 pin looms for general trailers i.e. Goods or horse boxes that don't need the extra electrics that caravans use? (I think the previous owner only ever pulled a horse box, and then not often)
Is it likely I'm just missing a relay or do I need to change the 13 pin loom for one with split relays etc to suit a caravan?
Thanks in advance for any help you can offer
Post #515016 11th May 2019 9:22pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I changed my twin plugs on mine for the single 13 pin type it was plug and go are you sure it's not the caravan? otherwise, check your fuse bank in the rear right side rear.
Post #515018 11th May 2019 9:28pm
MisterT
Not the van, it works fine connected to the Volvo V70. I'll check the fuses in the morning, that the ones on the side where the towbar stows?
Post #515019 11th May 2019 9:30pm
Tinman
That's right, also get into the spare wheel area that`s where the 13 pin connects to the loom double check the plug connection there?
Post #515048 12th May 2019 7:12am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Fuse 8 (15 Amp) in the rear fuse box is the one to check ...
 Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #515052 12th May 2019 8:17am
MisterT
Thanks guys for your replies,
The trailer loom in the wheel well plugs into a socket in the main wiring loom just by the spare wheel, no spare wires and the plug and socket appear to be well plugged together.
I can't see a split relay anywhere, but guess that is perhaps installed in the fuse board on the right of the boot.
There are no spare fuse or relay sockets on the board that have terminals in them and everything is installed as shown on the small schematic diagram below the fuse board
Fuse 8 (15 amp) checks out OK
Can't see anything else to check and don't have a multimeter with me, guess it'll have to wait until I get back to Lincolnshire and get it checked out at Duckworths
Post #515096 12th May 2019 5:06pm
