Home > Technical (L322) > 2011 tdv8 AB 13 pin towing electrics |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
I changed my twin plugs on mine for the single 13 pin type it was plug and go are you sure it's not the caravan? otherwise, check your fuse bank in the rear right side rear. |
11th May 2019 8:28pm |
MisterT Member Since: 08 Mar 2019 Location: Lincolnshire Posts: 29 |
Not the van, it works fine connected to the Volvo V70. I'll check the fuses in the morning, that the ones on the side where the towbar stows? |
11th May 2019 8:30pm |
That's right, also get into the spare wheel area that`s where the 13 pin connects to the loom double check the plug connection there? |
12th May 2019 6:12am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
Fuse 8 (15 Amp) in the rear fuse box is the one to check ...
12th May 2019 7:17am |
Thanks guys for your replies,
12th May 2019 4:06pm |
