Home > In Car Electronics (L322) > new things to try |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
the top dvd unit with the lock button is your sat nav, the one below it is an aftermarket unit... |
5th May 2019 11:18am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 759 |
thanks Stan
8th May 2019 11:22am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
That's a bloomin good question -- you'd expect a DVD player to play DVD's but with just the red and white phono's then it does seem that it's simply being used for audio -- though if it plays mp3's, stored on a DVD, you'd have to go on a long journey to get through all of the possible tracks -- I'd estimate about 800 tracks on 1 DVD ! Current: 2011 FFRR Vogue SE 4.4 TDV8
8th May 2019 11:33am |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 |
Maybe that is for audio in not out and the outputs are on the other end. Current: RR L322 2010
8th May 2019 12:13pm |
now that's a thought too ! Current: 2011 FFRR Vogue SE 4.4 TDV8
8th May 2019 12:23pm |
Good call ianmacd !
8th May 2019 12:29pm |
there is a CD stacker behind the glove box, is that standard, if it is, from where would it be controlled RR 2005 4.4 petrol
8th May 2019 1:40pm |
If you mean in the glove box, then yes it standard, controlled from the head unit Current: 2011 FFRR Vogue SE 4.4 TDV8
8th May 2019 1:42pm |
LivingtheDream Member Since: 06 Feb 2019 Location: Baldock Posts: 35 |
are the red and white plugs bottom left of your pic connected - i.e. the other end? |
8th May 2019 1:43pm |
LivingtheDream
8th May 2019 2:56pm |
Bushy30
8th May 2019 2:58pm |
The big radio thing in the front Current: 2011 FFRR Vogue SE 4.4 TDV8
8th May 2019 3:01pm |
8th May 2019 3:03pm |
ok
8th May 2019 3:04pm |
