![]() | Home > In Car Electronics (L322) > new things to try |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35531 ![]() ![]() |
the top dvd unit with the lock button is your sat nav, the one below it is an aftermarket unit... |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 772 ![]() ![]() ![]() |
thanks Stan
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
That's a bloomin good question -- you'd expect a DVD player to play DVD's but with just the red and white phono's then it does seem that it's simply being used for audio -- though if it plays mp3's, stored on a DVD, you'd have to go on a long journey to get through all of the possible tracks -- I'd estimate about 800 tracks on 1 DVD ! Current: 2011 FFRR Vogue SE 4.4 TDV8
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Maybe that is for audio in not out and the outputs are on the other end. Current: RR L322 2010
now that's a thought too ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Good call ianmacd !
there is a CD stacker behind the glove box, is that standard, if it is, from where would it be controlled RR 2005 4.4 petrol
If you mean in the glove box, then yes it standard, controlled from the head unit Current: 2011 FFRR Vogue SE 4.4 TDV8
LivingtheDream Member Since: 06 Feb 2019 Location: Baldock Posts: 35 ![]() ![]() |
are the red and white plugs bottom left of your pic connected - i.e. the other end? |
LivingtheDream
Bushy30
The big radio thing in the front |
ok
