Home > Maintenance & Mods (L405) > Condensation in Rear Cluster
borse2008
United Kingdom 2013 Range Rover Vogue SE TDV6 Causeway Grey
Is this a common problem ive read a tiny small hole is needed but would it be covered under a land rover warranty ?
Post #514492 6th May 2019 8:04pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Is there liquid water running around inside the lamp? If not, I’ve had varying degrees of condensation, on and off, from new with my 2017 car. I doubt if there’ll be a warranty claim as it’s even mentioned in the handbook as simply being a characteristic that usually clears when the weather changes Thumbs Up
Post #514497 6th May 2019 8:20pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I know it`s not a 405, I have the same problem with mine L322, what I did was take it off the car it has 2 rubber caps which I removed I then put my blow gun from my compressor and blew it through which cleared the moisture replaced the caps and reinstalled worked for me?
Post #514509 7th May 2019 5:52am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Again this is on a L322. My LH side had condensation and liquid water of about a quarter inch depth in the bottom. The RH side being totally clear and dry. I took the LH cluster off and drilled three holes in the bottom. It's now totally clear, no condensation. However, I wouldn't do that if it was under warranty.
But in the OP's case, if one has condensation and the other doesn't, surely that means it's defective, i.e. a seal is not working and allowing water ingress.
Post #514510 7th May 2019 7:04am
supershuttle
Ive just bought an L405 and from what I can see the only thing that needs some attention is condensation in one of the rear lights. It does disappear in cold weather but then leaves a mark. Has anyone successfully fixed it and can the light unit be "rinsed out" to remove the mark like I did with my L322 front lights. Geoff
Post #516550 26th May 2019 11:54am
supershuttle
https://www.ebay.co.uk/itm/Captain-Tolleys...SwXIdcTDuB
I'm sure there is a better way to put an eBay link but has anyone tried this stuff. I've just bought some and it looks ideal for what I need. Link might not work in that case just search for Capt. Tolley. Geoff
Post #516763 28th May 2019 11:07am
link doesnt work for me geoff..
the condensation in the rears lights is a common problem, its even mentioned in the owners manual...
Post #516765 28th May 2019 11:47am
supershuttle
Yea I got a bit in my L322 but this new one has a lot. Drying it out in the sunshine as we speak, yep link is rubbish doesn’t work for me either Shocked Geoff
Post #516776 28th May 2019 1:59pm
nino_nino
works for me-
https://www.ebay.co.uk/itm/Captain-Tolleys...SwXIdcTDuB 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #516836 29th May 2019 8:27am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I was always getting water/condensation in the LH rear lamp but never the RH so I figured it must be a failure of sorts.
When it rained I took a look at both lamps and both had water pooling on the top of the housing externally, I took the LH lamp out and looked extremely carefully at the sealing around the top edges and found what “could have been” a minute difference in the sealant area, so after drying out the lamp indoors with a blow heater just warming it up for a day I smeared some black silicone sealer along the area, after that the lamp remained as the RH lamp......dry. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #516838 29th May 2019 9:01am
supershuttle
Unit is now free of condensation but there are marks on the inside of the glass. Looks like the next stage is to "inject" some water through one on the three holes in the base (I assume drilled by the previous owner) and see If they will rinse away before finally drying again and the sealing.
I have an old syringe I can use so first hot soapy water then rinse with boiled water,
I'll block up the holes I'm not injecting through with blu tack first to stop water immediately draining out - what could possibly go wrong?
It is the LH lamp as well. Geoff
Post #516842 29th May 2019 9:16am
Boxbrownie
I had some old headlamps which had formed a slight “haze” on the reflectors and obviously impossible to clean as a sealed unit, I didn’t fancy trying water inside and drying out as the silvered reflector surface might have been damaged/marked.
So thinking laterally I put a cup full of rice (dry of course Laughing ) into the lamp and gave the unit a bl00dy good shake for a while, upon emptying the rice through the bulb hole the reflector surface was shiney and clean Thumbs Up
Don’t know if it would work with water marks on the plastic lens but couldn’t do much harm, as long as you can see it would all come out of course Wink David
Post #516844 29th May 2019 9:24am
