Home > Technical (L322) > Occasional Transmision fault?
Tight777
Every now and again when I start up I get the warning Transmisin fault, limited gears.
If I drive I'm stuck in 3rd.
Switch off, re start and all is fine, drives perfect, recently did 550 mile round trip with no errors.
once or twice when re starting I get nothing not even a click from starter, even though lights are on.
The battery sounds really strong when starting, no slowness in cranking although as it fires straight away that maybe hard to tell.
Any thoughts?
Post #501656 15th Jan 2019 3:03pm
Tight777
New battery seems to have cured it.
Post #509978 27th Mar 2019 10:02am
Dustbolt
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Santorini Black
just noticed this post, after I posted about almost same thing - is it still ok with new battery?
Post #514267 4th May 2019 6:25pm
Tight777
Not had it happen since.
Post #514280 4th May 2019 8:25pm
Dano0404
Had the same battery sorted it 2007 sc
Post #514300 4th May 2019 10:17pm
