![]() | Home > Technical (L322) > L322 2011 4.4 TDV8 Suspension / compressor fault |
FYI I had a brand new replacement do just that. Sent it back and the replacement was fine. They CAN fail out of the box. Do NOT assume new means working |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 ![]() ![]() ![]() |
UPDATE
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 ![]() ![]() ![]() |
You wouldn't happen to have a picture of what the little valve looks like, do ya? Im new to the RR but I have read plenty of posts about this little valve clogging. I'd like to do some preventive maintenance and clean it up and drill the hole...but I'm not quite sure where it's located. Any help appreciated! 2012 Range Rover Autobiography 91 BMW 850i 6 speed 94 BMW 850 CSi 6speed Supercharged Tbirds Audi S8, Audi V8 Quattro |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic23038.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Hat off to you, sir! Many thanks! 2012 Range Rover Autobiography
“You’re welcome!” as they say over your neck of the woods |
woodand Member Since: 22 Feb 2017 Location: Wrexham Posts: 6 ![]() ![]() ![]() |
Hi, Dont suppose you know the part number / technical name for this valve block do you ? Thanks |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Woody
Cheers.. |
