Home > Technical (L322) > L322 2011 4.4 TDV8 Suspension / compressor fault
Baz1975
Northern Ireland 2015 Range Rover Autobiography SDV8 Firenze Red
Hi all, looking for some pointers please.
Saturday night, 'bong' suspension fault, max speed 30mph, stopped car, restated and drove a couple of miles and same thing. Restarted and raised car to full height and then access height, returned to normal height, drove another couple of miles and same again, then 'compressor over temp' (I think was the exact words) got car home and left it.
Sunday, drove 40 miles with no issues.
Monday, drove 3 miles up the road and same fault, 'bong' suspension fault, max speed 30mph. Returned home, car goes up & down with now issues. Removed compressor cover and found the compressor very hot. Started car, steering wheel lock to lock and compressor cutting in & out as required with no issues. When driving, you can hear the compressor (left cover off etc) kicks off after 1 minute or so, ok for a few miles then all of a sudden 'bong' suspension fault, max speed 30mph, as soon as this happens, you can hear the compressor pulsing out air.
Phoned my INDY (who is away on holiday for Easter) he said, 1st thing to replace compressor. Left the car on full height mode for 2 days, no dropping at all.
Replaced the compressor & relay tonight, out for test drive and 'bong' suspension fault, max speed 30mph, again, as soon as this happens, you can hear the compressor pulsing out air.
Not happy, been searching through posts but unable to find something similar.
Any pointers would be greatly appreciated
Thanks in advance
Baz Current: 2015 4.4 SDV8 Autobiography
Old: 2011 4.4 TDV8.... OMG
Old: 2003 TD6 HSE Java Black
Work: 2016 VW T6 140
Post #512433 17th Apr 2019 8:48pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
You are in luck (sort of) my post 'suspension issues after towing' describes the exact symptoms you have
The compressor is getting hot as it can't get the system up to pressure and after so many cycles it pings up that warning as it has not achieved the correct height
I bet you have a leak - it was not immediately obvious which wheel was the problem on mine but when I was driving into work I plugged diagnostics in to watch the compressor temperature and the psi in the tank. When the compressor got to 280 F it cut out and the pressure started dropping.
I also monitored the 4x4 screen where it shows you the wheel heights from the screen in the car - this pointed to my front left getting low before the others (then it self levels) and sure enough that's where I found my leak.
They don't always leak at a specific height - jacking each corner up and down and use soapy water on the bags. Mine had perished on the fold of the bag at the bottom
Post #512482 18th Apr 2019 8:25am
Baz1975
Thanks, but my compressor gets up to pressure & cuts out as required, it doesn’t kick in again, therefore I’m under the understanding that the pressure is fine.
I’m lost! Current: 2015 4.4 SDV8 Autobiography
Post #512485 18th Apr 2019 8:52am
L19 MUD
Exhaust on the compressor not opening to allow it to start up again? Assuming it works like an unloading valve on a static compressor
Have you read the codes?
Post #512486 18th Apr 2019 9:04am
L19 MUD
Do you know the pressure is fine - I. E have you checked on diagnostics?
Post #512488 18th Apr 2019 9:05am
Baz1975
I don’t have a IID tool, hoping my sons mate will call over Easter and connect his up.
Thanks Current: 2015 4.4 SDV8 Autobiography
Post #512489 18th Apr 2019 9:15am
gavinn
Had the same sort of issue, there is a little screw in brass exhaust filter/silencer on the compressor that gets clogged, you can replace it , or do as i did , unscrew and throw away to replace at a later date (that was 2 years ago) , you will get a louder PSSSHHHH when the compressor exhausts but apart from that all good !
Post #512491 18th Apr 2019 9:18am
Baz1975
Thanks, but that is brand new along with the compressor. Current: 2015 4.4 SDV8 Autobiography
Post #512493 18th Apr 2019 9:30am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Might be worth looking at the plastic pipes and the big tubular reservoir on the drivers side to check for leaks, could even be that the bags are still fine, but the system from them back is leaking somewhere?
The rear valve block is inside the arch liner on the driver's side.
I saw an issue on here recently where one of the blue pipes had chafed and got a hole in that was causing weird suspension anomalies.
EDIT: as you say the compressor was swapped it could be worth re-checking all the pipe connections to that to ensure none are leaking. Formerly happymadison1978
Post #512496 18th Apr 2019 9:40am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Did you replace the compressor with the same make? if not I believe it needs to be programmed?
Post #512517 18th Apr 2019 2:08pm
DMRR
I got a valve block if you need one - the one closest to the compressor (i.e. IN the boot) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #512519 18th Apr 2019 2:29pm
Baz1975
Compressor changed like for like. Current: 2015 4.4 SDV8 Autobiography
Post #512606 19th Apr 2019 5:58pm
Baz1975
UPDATE:
I have a fault C1A36-01 Exhaust valve
Any idea where the exhaust valve is or is it called anything else?
Any help greatly appreciated! Current: 2015 4.4 SDV8 Autobiography
Post #512837 22nd Apr 2019 6:01pm
DrRob
Might need the exhaust valve brass filter thingy bored out with a drill. Common issue.
Search function on here is a useful feature Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #512840 22nd Apr 2019 6:07pm
Baz1975
Post #512841 22nd Apr 2019 6:13pm
