Home > In Car Electronics (L322) > Bassy vibration with sound system. |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
I have similar but haven't investigated yet. Not bad enough to trouble me but does rear its head on certain tracks. Will watch this thread with interest. 2016 Skoda Octavia VRS Estate
16th Apr 2019 10:17am |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Blown speaker, door card easy to get off, a little more fiddly to get back on , hardest part is making sure you detach all the electrical connectors properly , and on re assembly getting the top black plastic channel of the card seated correctly against the window , on a hardness scale its a 3 out of 10 |
24th Apr 2019 9:33am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Also worth checking your sub hasn't shaken free from it's bolts. Mine used to do this regularly - in the end I used loctite on the bolts! Land Rover Addict
24th Apr 2019 11:18am |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Bottom speaker in the drivers door is def faulty, slightest touch of the cone while sound playing causes buzzzzzz/distortion.
24th Apr 2019 1:22pm |
Said speaker... 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
24th Apr 2019 1:25pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Had the exact same problem with mine. Only my problem speaker was the front passenger bottom speaker. I bought a full set of speakers off ebay for 90 qiud and replaced said speaker. Its now perfect. Tony
24th Apr 2019 2:31pm |
Cheers I don't need a full set, just need to know if I can put a non harmon kardon speaker in as they seem physically the same. I'm not an audiophile.. as long as I can hear my Barry Manilow music... 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
24th Apr 2019 5:11pm |
Not too sure. But you're welcome to have the said speaker. it's no use to me. I did some checking when mine blew and was told that LR build to a price and that a lot of very low voltage and small wires are used. so it's difficult to replace with aftermarket without upsetting the BCU and the head unit.
24th Apr 2019 7:32pm |
That's very kind, thanks. If I can't resolve shortly I'll be in touch. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
25th Apr 2019 12:28pm |
alaahnx Member Since: 15 Jul 2020 Location: WI Posts: 13 |
Hi there,
14th Aug 2020 6:44pm |
Thegingerone Member Since: 21 Jun 2020 Location: South Wales Posts: 22 |
I had the same issue with my two rear door woofers.
15th Aug 2020 6:50pm |
