Home > In Car Electronics (L322) > Bassy vibration with sound system.
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi my speakers seem to have this buzzy bass distortion, seems especially bad from bottom front drivers door, improves with balance set fully to n/s.. Is the door card a pain to get off to examine the speaker? Common problem with speaker being loose or speaker likely to be fubared? Thanks for any info peeps. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #512162 15th Apr 2019 3:04pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I have similar but haven't investigated yet. Not bad enough to trouble me but does rear its head on certain tracks. Will watch this thread with interest. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #512238 16th Apr 2019 10:17am
gavinn
Blown speaker, door card easy to get off, a little more fiddly to get back on , hardest part is making sure you detach all the electrical connectors properly , and on re assembly getting the top black plastic channel of the card seated correctly against the window , on a hardness scale its a 3 out of 10
Post #512998 24th Apr 2019 9:33am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Also worth checking your sub hasn't shaken free from it's bolts. Mine used to do this regularly - in the end I used loctite on the bolts! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #513013 24th Apr 2019 11:18am
Rapiscan
Bottom speaker in the drivers door is def faulty, slightest touch of the cone while sound playing causes buzzzzzz/distortion.
Taken it out while I get a replacement, I see new harmon kardon speakers are circa £60.00 Shocked
There are a few on ebay that physically seem identical, same shape, holes etc with same wiring plug but maybe not harmon kardon for £15...surely be OK dya think? Thanks. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513032 24th Apr 2019 1:22pm
Rapiscan
Said speaker... 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513033 24th Apr 2019 1:25pm
Big Boy R44ROV
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
Had the exact same problem with mine. Only my problem speaker was the front passenger bottom speaker. I bought a full set of speakers off ebay for 90 qiud and replaced said speaker. Its now perfect. Tony
You're always in the Censored ........it's just the depth that varies
2011 5.0 Autobiography Fuji White
2019 Audi Q2 in White
04 SL55AMG
Gone:
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
V8 Lightweight
Too many series to mention !
IID for L322
Post #513052 24th Apr 2019 2:31pm
Rapiscan
Cheers I don't need a full set, just need to know if I can put a non harmon kardon speaker in as they seem physically the same. I'm not an audiophile.. as long as I can hear my Barry Manilow music... Laughing 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513070 24th Apr 2019 5:11pm
Rapiscan
Faulty speaker 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513071 24th Apr 2019 5:11pm
Big Boy R44ROV
Not too sure. But you're welcome to have the said speaker. it's no use to me. I did some checking when mine blew and was told that LR build to a price and that a lot of very low voltage and small wires are used. so it's difficult to replace with aftermarket without upsetting the BCU and the head unit.
That's what I was told .I could have been told a pack of u no what!. if you want the speaker it's yours but obviously cNt guarantee it.
if Tony
04 SL55AMG
Gone:
00 TD5 90 County
97 3.9ES Disco
V8 Lightweight
IID for L322
Post #513087 24th Apr 2019 7:32pm
Rapiscan
That's very kind, thanks. If I can't resolve shortly I'll be in touch. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #513144 25th Apr 2019 12:28pm
alaahnx
United States
Hi there,
Anyone could share a resource on how to take off/put back on the door card/panel? Have the same problem and sounds I need to replace a speaker or two.
Thanks,
A.
Post #564604 14th Aug 2020 6:44pm
Thegingerone
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Java Black
I had the same issue with my two rear door woofers.
Turned out the face of the cone had detached from the plate that it mounts too, decent bead of hot glue found the centre of the cone and they’ve been fine since
Post #564694 15th Aug 2020 6:50pm
