Home > My Range Rover > range rover with problems
Page 14 of 18 <123 ... 131415 161718>
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thanks for the link
i never did like the look of that kit i bought, i even took it in to BMW and asked them if it looked ok, they said the angles looked ok, a guy on YouTube said the Chinese ones were no good
" I had the P011 code after my TCG guide replacement when I used rental tools from bimmertoolrental.com. I found the same post and bookmarked it before I went back in to replace the Vanos units. (Just in case the P011 came bank) This time I bought a set of tools from GAS and I ended up with no codes after I finished the repair.
I wonder if the GAS tool for setting the timing wheels is more exact? It has a single point of attachment, screwing into the the solenoid threads (solenoid removed). Regardless, I am happy with the results and love the low end torque that is back." RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #512978 24th Apr 2019 1:55am
knares
top timing chain covers, i wasn't happy with ether of them, had to take the left one off and put it back on a gain to get it in line
"I also had the same problem timing a 2002 540iA after doing the timing chain guide rails and it turned out to be the upper timing covers. There is enough play in those covers to allow the cam sensors to be out of place. The covers have to be forced down as far as possible before the bolts are tightened. BMW actually sells plastic spacers (just like the VCG) to install under the valve covers to help force down when tightening the upper timing chain covers. You then remove the spacer and finish your installation of the VCG, etc. I don't think they are necessary as long as you know the covers have to be forced down when tightening the upper covers." RR 2005 4.4 petrol
Post #512979 24th Apr 2019 2:01am
holidaychicken
I think there is screw you can remove from the front upper timing covers which enables you to check the timing against the cam trigger wheel but don’t know if it can be done with the top cam covers on or even if it is correct what I’m saying. I know the screws in question but don’t know the procedure , that is a lot of don’t knows I appreciate .
I’m away today but back tonight so might be able to find out a bit more info later.
I used the Chinese kit but the trigger wheel timing jug had been modified by the previous owner as it was wrong. I also purchased the full GAS kit which is a pleasure to use.
Post #512987 24th Apr 2019 8:46am
knares
After reading a lot of those posts, I have come to the conclusion that the position of the crank has nothing to do with it.
Providing the vanos is fully anti clockwise when fitted, it is solely the position of the timing plate and the position of the sensor.
The position of the timing plate relies on the tool used to set it up
The position of the sensor relies on getting the top timing chain cover in the right position
What do you think, am I missing some thing RR 2005 4.4 petrol
Post #513014 24th Apr 2019 12:20pm
Essex1959
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Quote:I still have to fit the right park/flasher light, over the last few days several people have tried to get there hand in and put the plastic nut on, but so far no look
I found that removing the one bolt securing the air box and removing it made the job of getting the plastic wing nut on a doddle
Post #513081 24th Apr 2019 7:59pm
holidaychicken
I think the crankshaft position sensor determines the rpm of the engine, not sure what else it does.
have you got the rave manual system description and operation as there are pages of information detailing every aspect of what the engine is doing and how it adjusts the cam timing and vanos etc?
here is one of the many pages.
i think you are correct in getting the timing cover fitted incorrectly will alter the timing but I am not sure if that is enough to throw a fault but if the timing tools are not correct then that would.
The Chinese set i had were modified by the previous owner as they were in the wrong place so he used a known good set to set the timing wheels and then moved the arm of the wrong set to match the engine and then fixed it in place. the actual locking blocks were ok, it was the trigger whel jig that was wrong on one bank.
Post #513083 24th Apr 2019 8:10pm
knares
was it wrong no the left bank or the right bank??? RR 2005 4.4 petrol
Post #513085 24th Apr 2019 8:29pm
holidaychicken
If I had to guess I would say bank 2 or right hand as looking at the front
Post #513104 24th Apr 2019 11:30pm
knares
HMMMMMMMMM different side to mine RR 2005 4.4 petrol
Post #513110 25th Apr 2019 1:11am
holidaychicken
It was only a guess, I’ll have a look in my garage when I get time to move stuff so I can get to the box.
Post #513114 25th Apr 2019 7:10am
knares
i know the feeling RR 2005 4.4 petrol
Post #513124 25th Apr 2019 9:34am
holidaychicken
How does it sound and drive, is it missing or does it just say it is missing ?
Post #513205 25th Apr 2019 8:53pm
knares
thanks
i did look at removing the air filter but didnt think it would help, i will remove it, now you have said that and give it a try RR 2005 4.4 petrol
Post #513233 26th Apr 2019 2:41am
knares
Essex1959
i did as you said and now the light is fitted
thanks
after removing the air filter housing, i still couldn't get my hand in but with the help a 1/4 socket set it was quite easy RR 2005 4.4 petrol
Post #513268 26th Apr 2019 12:43pm
Essex1959
Glad you are sorted Thumbs Up I have big hands and managed to screw the nylon wingnut on with the filter box removed. Your hands must be like shovels Laughing
Post #513277 26th Apr 2019 1:15pm
