Home > Technical (L322) > Misfire problem |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Any tips on fitting new cam shaft sensor? |
17th Apr 2019 9:19pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
when you cleared faults, what faults came back on diagnostics , just misfire 1 and 2 ?
18th Apr 2019 12:04am |
Cheers holiday that would be a relief if it's not valley .looking at the state of the sensors in pics I think I will give mine a clean see if it helps multiple persistent misfires cly 1 /2 cam shaft timing over advanced although this goes away when coils changed or plugs .She was running well last night will see what happens in the morning.not getting a lot of sleep at the moment with the pain etc hence early morning message.thanks again Richard |
18th Apr 2019 4:28am |
Oh and what I ment is plug hole with plug still in I squeezed a small sponge down the side of the plug and let it soak a while the dried it on a cloth the result was a reddish pink fluid hence the worry of anti freeze.cant see where it can be coming from unless it is oil |
18th Apr 2019 4:38am |
Check if it is the same colour as your oil from inside the filler cap, also check the crankshaft sensor.
18th Apr 2019 6:03am |
Hi cleaned camshaft sensors {they were pretty mucky}fired her up and she ran perfect no rattles on start up firing all cylinders.vanos never been disturbed by me at least .Going to Greenock today so that will test her fingers crossed,☺️ |
18th Apr 2019 8:28am |
Ok whatever I did it seems to have worked not a blip from her running better than ever super quite and responsive happy again.at the moment anyway!! |
18th Apr 2019 2:56pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
18th Apr 2019 5:27pm |
Cool, hopefully you are done |
18th Apr 2019 11:43pm |
Not holding my breath confidence is a bit low waiting on the next problem |
19th Apr 2019 9:51am |
Don't forget you have bought a 10,000 piece puzzle, you will be bored when you complete it |
19th Apr 2019 11:12am |
Do you think it is solvable?My FSR just packed in luckily I have a spare it never seems to end ☺️ |
19th Apr 2019 11:17am |
I am guessing you have heard of the Forth Bridge.
19th Apr 2019 12:02pm |
At least it will be easier second time around if I not in the funny farm by then 😊 |
19th Apr 2019 1:55pm |
