![]() | Home > Technical (L322) > Misfire problem |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Any tips on fitting new cam shaft sensor? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
when you cleared faults, what faults came back on diagnostics , just misfire 1 and 2 ?
cam shaft sensors are 1 bolt each side https://www.pelicanparts.com/techarticles/...lacing.htm I'm not sure on your crankshaft sensor, have a look in rave |
Cheers holiday that would be a relief if it's not valley .looking at the state of the sensors in pics I think I will give mine a clean see if it helps multiple persistent misfires cly 1 /2 cam shaft timing over advanced although this goes away when coils changed or plugs .She was running well last night will see what happens in the morning.not getting a lot of sleep at the moment with the pain etc hence early morning message.thanks again Richard |
Oh and what I ment is plug hole with plug still in I squeezed a small sponge down the side of the plug and let it soak a while the dried it on a cloth the result was a reddish pink fluid hence the worry of anti freeze.cant see where it can be coming from unless it is oil |
Check if it is the same colour as your oil from inside the filler cap, also check the crankshaft sensor.
Hi cleaned camshaft sensors {they were pretty mucky}fired her up and she ran perfect no rattles on start up firing all cylinders.vanos never been disturbed by me at least .Going to Greenock today so that will test her fingers crossed,☺️ |
Ok whatever I did it seems to have worked not a blip from her running better than ever super quite and responsive happy again.at the moment anyway!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Cool, hopefully you are done |
Not holding my breath confidence is a bit low waiting on the next problem |
Don't forget you have bought a 10,000 piece puzzle, you will be bored when you complete it |
Do you think it is solvable?My FSR just packed in luckily I have a spare it never seems to end ☺️ |
I am guessing you have heard of the Forth Bridge.
At least it will be easier second time around if I not in the funny farm by then 😊 |
