Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 4 of 42 <123 45 ... 404142>
Mr Tee
Well I've educated myself with the incredible insight from Greg & Mike over a couple of highly detailed threads, it's amazing what determination and not accepting "they all do that sir" attitude. Been putting off on an IID for years to be honest. At least the car has a full warranty covering the dpf system. Sincere thanks to you both. Seems as though the cars want to do a burn per full / empty tank cycle. Waiting on some huge invoices coming in then IID tool order will be placed Bow down
Post #511796 12th Apr 2019 9:48am
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
I don't think the iiD tool is sorted yet for the 17MY unfortunately. Possibly couldn't trust myself with one anyway. Bound to screw it completely. Rolling Eyes
Post #511797 12th Apr 2019 9:51am
Mr Tee
That's always been my worry Huw. One wrong button press and you're completely stuck. What does this do, click Mr. Green , then your sitting in a smoldering pile of ashes
Post #511799 12th Apr 2019 9:57am
GGDR
Quote:
If the regen should take 30 mins, and I only manage say 20 mins before hitting a traffic light or similar, do I have to start all over again?
Can't give you a black and white answer on this one. It won't be wasted, a full regen will take the soot down to maybe 2g. So if it's coming down and you have to abort you won't loose what it's burnt; if it's burning and gets to 10g and you stop, you're finished at 10g, just not 2g so you're better off. The ECU won't trigger another until 17g so you won't really be able to resume because the ECU thinks you don't need one. You'll just need another sooner, like in a week or two.
. Cheers, Greg
Post #511803 12th Apr 2019 10:15am
Bill
Thanks Smile Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #512004 14th Apr 2019 8:37am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hello Everyone, my first post.
Yesterday I had the amber DPF and soon after the red.
The car (2012 4.4 TDV8) went into limb mode.
While I got the amber DPF I was driving spirited to test the CSOV that I removed earlier that day to clean and grease the valve linkage after a P2263 error last week ( I have the updated valve stem without the nut)
There was a little bit of oil on the bottom of the CSOV, no more than a couple of drops.
I drove home in limb mode and went online to read what the @#%$ happened and found a lot of info here on fullfatrr (that's why I signed up today)
This morning I connected my old OBDII reader (ODBLink with ScanXL software) to check the codes and it only showed one pending code P2463 - DPF Restriction / Soot Accumulation and I cleared it.
Started the car, no error messages and drove away and within seconds it showed the amber DPF.
After about 10 minutes of highway driving at steady 120km/h the amber DPF went away.
I drove another 30 minutes and everything seems ok now.
Is everything really ok?
Is there a way to get values of the differential pressure or is that converted into soot levels in gram by the scan tools?
Is there a way to see how good/bad my DPF is at the moment?
And... what about the type of fuel?
Does that play a role at all?
I've been using the Aral (BP) Ultimate Diesel since I've owned the car, I bought the car a year ago with 115000km, now at 130000.
See-ya,
SpitfireS
Post #517974 10th Jun 2019 4:44pm
Baltic Blue
Greg is the site expert on 4.4 tdV8 DPF’s and will probably have plenty more info for you later, but for now, my fourpeneth,
Most of us use Gap iid readers which show live values for DPF soot Mass.
Anything in single figures is good.
As soon as the mass reaches 17.5g start planning to go for a 20/30 minute run at 50mph+.
If you don’t, the mass figure will continue to rise until at 23.5g the Amber warning will trigger.
Post #517983 10th Jun 2019 5:21pm
DrRob
Mike
Could you post an idiots guide in here on how to set up the IID so you can see the correct parameters whilst driving?
Cheers
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517984 10th Jun 2019 5:30pm
Baltic Blue
This screenshot shows a typical Active regen cycle.
Post #517985 10th Jun 2019 5:31pm
Baltic Blue
Soot mass at start =19g.
Exhaust temperature at cold shows 100 deg.
Temperature rises to 600 deg and soot level falls to 10g.
Another couple of minutes and temperature peaks at 620 deg.
At which point soot mass down to 2.3g.
Post #517988 10th Jun 2019 5:37pm
GGDR
Thank you Mike
Bow down Bow down I'm self-taught through hard knocks!
Well Herr SpitfireS, I think you've just found tool that will remove a RED DPF warning!
Congratulations and thank you! Bow down Bow down
Only thing I'd add which Mike has summarised very well is that you should check your soot level - which the lack of Amber suggests is fine. Should be 3-5g maybe less after a successful regen.
The IIDTool does not have this feature which is a shame and if a few of us lobby GAP maybe they will reconsider. I've asked Pat and he said they considered it but decided not to add. Maybe from a liability POV they are worried people may clear the warning but not actually go immediately on a Regen run which you did do Spitfire.
I imagine somebody could easily FUBAR their DPF and maybe more if they cleared a RED and didn't regen immediately.
Well done and thanks for posting a solution!! Thumbs Up Thumbs Up Thumbs Up
Oh and welcome - loving your username! Thumbs Up
. Cheers, Greg
Post #517997 10th Jun 2019 6:54pm
GGDR
Anyone know how much a OBDLink and ScanXL costs?
Links welcome, could not find it quickly Thumbs Up
. Cheers, Greg
Post #517999 10th Jun 2019 6:57pm
DrRob
Thanks Mike Thumbs Up
Any idea why Bank 2 Sensor 1 hasn’t moved from 100? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518006 10th Jun 2019 7:51pm
SpitfireS
Haha, Herr... yeah, well I live in Germany but I'm Dutch Laughing
The OBDLink I have is 8 years old, bought from Scantool.net
https://www.scantool.net/obdlink-scan-tool/
I was surpriced this morning to see they offer a firmware update for it, installed it, it still works.
The ScanXL software I bought from
https://www.palmerperformance.com/products/scanxl/index.php
Looks like they still sell it, they also had updates for it.
I did not start the car before I connected the OBDII and 'cleared' the red warning so I don't know if the red warning was still there, IOW did I really clear it?
Maybe it did not set as I just before worked on the CSOV?
Maybe it was a false error?
Or is the P2463 the Red Warning?
Oh well... I'll see tomorrow morning if everything is still ok.
My morning commute is just under 20km and only the middle bit, around 10km, is Autobahn Wink
Until now that was enough to never show any DPF warning.
Any thoughts on the fuel?
See-ya,
SpitfireS / Marc
Post #518007 10th Jun 2019 7:57pm
ilard
BP Ultimate is obviously good fuel with cleaning agents included but it would not be as powerful as specialist additive.
I've read good things about this product:
https://www.powerenhancer.co.uk/archoil-ar...e-639.html
But there are loads of alternatives. I think worth dropping one in the tank and seeing how things go. Question
Post #518008 10th Jun 2019 8:06pm
