![]() | Home > Technical (L322) > Interesting fbh discovery today. Nrrows down the problem??? |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
It won’t run if the battery is even a little bit low. With engine running, alternator will provide plenty of power. That sounds like the most likely reason to me. Current: 2010 Range Rover L322
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
I had 12.04v engine off.
Fully charged, with no load, should be 12.7v. That will quickly reduce, though, with any sort of load so hard to test and get a reliable value without disconnecting the battery from the car.
Thanks for this bud.
Quick and easy up to MY2010. 2011-12, slightly more involved. Always awkward - they are big, heavy batteries.
