Home > Technical (L322) > Interesting fbh discovery today. Nrrows down the problem???
dazza1983
Ok interesting discovery today
So the fuel burning heater comes on and works with the engine running. I have read that this is to help the engine warm faster and reduce wear.
I physically felt very warm air coming from it’s exhaust when the engine was running so the fuel burning heater does work and so must the glow plug etc. Otherwise it wouldn’t be able to fire up with a cold engine.
So it stands to reason that either the module or a temp sensor is stopping the parked heating working?? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #511267 7th Apr 2019 8:57pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
It won’t run if the battery is even a little bit low. With engine running, alternator will provide plenty of power. That sounds like the most likely reason to me. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #511274 7th Apr 2019 9:46pm
dazza1983
I had 12.04v engine off.
Thoughts? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511276 7th Apr 2019 9:54pm
steveball
Fully charged, with no load, should be 12.7v. That will quickly reduce, though, with any sort of load so hard to test and get a reliable value without disconnecting the battery from the car.
I would connect a battery charger overnight and the try FBH in the morning with battery charger still connected. FBH should run for at least 20 mins.
If this works, you need to look into the battery and charging circuit. If battery is original, it may well need replacing. Alternator charging voltage isn’t straightforward on these vehicles. It should get to about 14.4v (possibly a bit more for an AGM battery) but the charge controller stops alternator providing full output until the engine has been running for a few mintes, I think because the engine is more efficient and so emits fewer emissions once warm.
Also bear in mind that you need a fairly chilly morning for the FBH to fire up at all. Current: 2010 Range Rover L322
Post #511278 7th Apr 2019 10:05pm
dazza1983
Thanks for this bud.
I think I will go to my local car parts shop tomorrow. They have a battery tester which will say if it’s good or bad.
One question as I was looking earlier. How on earth do you replace the battery??
I know how to do it but can’t see how you get it in or out lol. There seems to be something in front like a big metal fin thing
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511282 7th Apr 2019 10:25pm
steveball
Quick and easy up to MY2010. 2011-12, slightly more involved. Always awkward - they are big, heavy batteries.
Article here gives details, with pictures.
https://www.fullfatrr.com/forum/topic43662.html Current: 2010 Range Rover L322
Post #511283 7th Apr 2019 10:30pm
