Home > Technical (L322) > Compressor Type/Manufacturer |
Twistedjack Member Since: 26 Oct 2016 Location: Glasgow Posts: 20 |
Yeah
22nd Mar 2019 10:33am |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Thanks mate. Regards
22nd Mar 2019 10:55am |
Right, that's it sorted...
22nd Mar 2019 1:25pm |
What is that lol? Regards
22nd Mar 2019 1:45pm |
Well fingers crossed my access mode gremlin will go away now lol.
23rd Mar 2019 3:53pm |
Nice one, did it work? |
23rd Mar 2019 4:06pm |
Haven’t tested it properly yet lol.
23rd Mar 2019 5:09pm |
Mines a 2011 and I needed to drill it.....
23rd Mar 2019 5:29pm |
Thanks for letting me know that.
23rd Mar 2019 6:04pm |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
Our 08 TDV8 is going to have its second compressor fitted tomorrow. First one (hitachi) was replaced under warranty and an AMK put in (with software changed) in 2014. This time the fault thrown up is the front crosslink valve fault and gallery not loosing pressure. This led us to the compressor exhaust not letting air out.
26th Mar 2019 7:10am |
Gallery not losing pressure was my error.
26th Mar 2019 9:07am |
So are we just bodging it by drilling the exhaust / silencer? Regards
26th Mar 2019 9:15am |
Not really. It’s blocked. It’s a silencer. it’s blocked over time. You can take it off by unscrewing it and soak it in Petrol etc or use an air line and see if you can get the crud out, but it’s far easier to drill it and it won’t block again.
26th Mar 2019 9:41am |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 |
Another 2011 here , had problems lowering shortly after I got it , removed silencer and cleaned it , helped but not perfect , 3 mm hole in end and no issues in last 3 years , if the silencer gets blocked (moisture causes corrosion to build up) then air doesn't escape fast enough , ecu then sees it's not dropping quick enough and thinks the car is sat on an obsticle and then jacks it back up and starts throwing a wobbly , if in doubt remove silencer for a week and see what happens , if all ok drill a hole in the end (it's fairly thick) and refit silencer . |
26th Mar 2019 9:45am |
