Home > Technical (L322) > Compressor Type/Manufacturer
Page 2 of 3 <123>
dazza1983
Cheers mate.
So you drill through the entire thing? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #509530 22nd Mar 2019 11:32am
Twistedjack
United Kingdom 2006 Range Rover Vogue SE Td6 Bonatti Grey
Yeah
But it's not as much as you think, it's a hollow cone. So you're drilling a hole at the top until it's right through to allow it to breathe.
Post #509531 22nd Mar 2019 11:33am
dazza1983
Thanks mate. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509533 22nd Mar 2019 11:55am
Twistedjack
Right, that's it sorted...
Cut out either side of the hole, pushfit straight through adaptor to fix.
Thanks all.
Post #509554 22nd Mar 2019 2:25pm
dazza1983
What is that lol? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509556 22nd Mar 2019 2:45pm
dazza1983
Well fingers crossed my access mode gremlin will go away now lol.
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509640 23rd Mar 2019 4:53pm
Twistedjack
Nice one, did it work?
Post #509642 23rd Mar 2019 5:06pm
dazza1983
Haven’t tested it properly yet lol.
I started the car and went from access to normal and then back down to access and I must admire it did lower faster than it has since I’ve owned it.
So fingers crossed.
Off out for a meal tonight so more testing. But I really hope so.
Thing I find strange is my car is late 2011 and if this part was modified from Land Rover I would have thought the later cars would come with the hole in already. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509647 23rd Mar 2019 6:09pm
mjdronfield
Mines a 2011 and I needed to drill it.....
No issues still after I did it.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #509649 23rd Mar 2019 6:29pm
dazza1983
Thanks for letting me know that.
I’ll test and report back. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509652 23rd Mar 2019 7:04pm
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Our 08 TDV8 is going to have its second compressor fitted tomorrow. First one (hitachi) was replaced under warranty and an AMK put in (with software changed) in 2014. This time the fault thrown up is the front crosslink valve fault and gallery not loosing pressure. This led us to the compressor exhaust not letting air out.
Rather than mess around for ages I thought we would put another compressor in and be done with it. Island 4x4 were 630 inc VAT and no need to return the old compressor. Daft though as the compressor works really well...it’s just the exhaust bit. '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #509858 26th Mar 2019 8:10am
mjdronfield
Gallery not losing pressure was my error.
Drill the exhaust. Best part of £900 saved.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #509868 26th Mar 2019 10:07am
dazza1983
So are we just bodging it by drilling the exhaust / silencer? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #509870 26th Mar 2019 10:15am
mjdronfield
Not really. It’s blocked. It’s a silencer. it’s blocked over time. You can take it off by unscrewing it and soak it in Petrol etc or use an air line and see if you can get the crud out, but it’s far easier to drill it and it won’t block again.
You used to be able to buy an new exhaust but not sure if you can now.
To prove it’s your issue, unscrew it and remove it. See if the car works fine.
Theoretically it will sound noisier with pump running, but I’ve not noticed mine.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #509871 26th Mar 2019 10:41am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Another 2011 here , had problems lowering shortly after I got it , removed silencer and cleaned it , helped but not perfect , 3 mm hole in end and no issues in last 3 years , if the silencer gets blocked (moisture causes corrosion to build up) then air doesn't escape fast enough , ecu then sees it's not dropping quick enough and thinks the car is sat on an obsticle and then jacks it back up and starts throwing a wobbly , if in doubt remove silencer for a week and see what happens , if all ok drill a hole in the end (it's fairly thick) and refit silencer .
Post #509872 26th Mar 2019 10:45am
Page 2 of 3 <123>
