![]() | Home > Technical (L322) > Blind spot monitor fault during heavy rain |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 218 ![]() ![]() ![]() |
Think I may have a water ingress issue with my blind spot monitor system. Twice now while driving in heavy rain the the blind spot monitoring system has failed with the warning message "BLIND SPOT SENSOR INACTIVE" or similar.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Behind the bumper -- you can see the brackets if you remove the rear light assemblies Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks. Damn, wish the problem had occurred two months back when I had the rear park distance control loom replaced. They could have checked the blind spot sensor while they were at it |
