![]() | Home > Technical (L322) > upper tailgate rubber marking lower tailgate |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Morning Dazza
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Morning buddy,
Hi Dazza,
Ah i didnt know that lol,
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Would have thought that upper tailgate is correct when flush with rear opening on both sides and latching without undue pressure? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
my thoughts too, flush with rear lights / rear quarter panel curve.. Regards
To tell if stops are wound too far in try pressing in
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Just trial and error I believe. Unless my stoppers are a good few turns out from the body work I get a really woolly close. Just give them a half turn on either side and close, check the gaps from the tailgate to the rear quarters, and assuming it's stopped smacking the lower tailgate you're done, if not, go again |
thanks guys
I'm not sure if it's case by case, because mine still latches fine when the bolts are nearly out, but you can tell that it's not quite in line, and the noise on closing is a bit tinny. Bearing in mind your issue, I'd just keep going out in quarter turns until you're just out of line, then go back in a bit. You won't have problems latching, but should minimise the marking on the lower tailgate |
Thanks buddy Regards
Hi Daz,
Here ya go buddy
Many thanks |
