Home > Technical (L322) > upper tailgate rubber marking lower tailgate |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Morning Dazza
13th Mar 2019 9:23am |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
Morning buddy,
13th Mar 2019 10:18am |
Hi Dazza,
13th Mar 2019 11:08am |
Ah i didnt know that lol,
13th Mar 2019 12:53pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Would have thought that upper tailgate is correct when flush with rear opening on both sides and latching without undue pressure? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
13th Mar 2019 3:26pm |
my thoughts too, flush with rear lights / rear quarter panel curve.. Regards
13th Mar 2019 3:28pm |
To tell if stops are wound too far in try pressing in
13th Mar 2019 3:30pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Just trial and error I believe. Unless my stoppers are a good few turns out from the body work I get a really woolly close. Just give them a half turn on either side and close, check the gaps from the tailgate to the rear quarters, and assuming it's stopped smacking the lower tailgate you're done, if not, go again |
thanks guys
13th Mar 2019 3:40pm |
I'm not sure if it's case by case, because mine still latches fine when the bolts are nearly out, but you can tell that it's not quite in line, and the noise on closing is a bit tinny. Bearing in mind your issue, I'd just keep going out in quarter turns until you're just out of line, then go back in a bit. You won't have problems latching, but should minimise the marking on the lower tailgate |
13th Mar 2019 3:49pm |
Thanks buddy Regards
13th Mar 2019 4:00pm |
Hi Daz,
13th Mar 2019 4:18pm |
Here ya go buddy
13th Mar 2019 4:31pm |
Many thanks
13th Mar 2019 4:35pm |
