Home > Maintenance & Mods (L322) > Best way to jack one side of the FF
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Opening doors, putting hazard lights on etc. does nothing - hence why it’s not mentioned in the handbook.
Post #507894 7th Mar 2019 10:25pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
That's not true. Opening a door interrupts a suspension height change for safety reasons. It may not prevent adjustments but it stops a change between access / standard / exetended height. It even shows up on the info display when it happens. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #507898 7th Mar 2019 10:52pm
It used to be the tailgate as well as any doors on the P38A - I believe the hazard warning lights were simply that:
"Warning Range Rover being jacked!!"
On the L322 you can leave a side door open, or you can try the inhibit switch on the console, or use your iiDTool to disable the EAS.... .
Post #507910 8th Mar 2019 12:06am
Philip
My point is that there’s no real benefit to doing it when you’re just changing a wheel - if there was, it would be detailed in the handbook.
Post #507918 8th Mar 2019 3:17am
MikeO
Maybe not for just changing a wheel. But anytime a part of me is going to go between a sprung piece of the FF and an unsprung piece (or anything else that's fixed), I do it. Anything that easy to do that might prevent a height change seems worthwhile to me. 2016 Skoda Octavia VRS Estate
Post #507926 8th Mar 2019 9:24am
Fraynizzle
United Kingdom 2005 Range Rover Vogue Td6 Java Black
the manual only mentions jacking to lift the body, using jacking points and subframes not suspension arms.
I've only done it this way and never had any issues with suspension adjusting.
maybe if you jack it up using the suspension arms you start getting issues because the EAS thinks the wheels are moving through travel...?
Post #507962 8th Mar 2019 12:10pm
Fraynizzle
from the workshop manual regarding air suspension inhibit modes, make of it what you will.
Post #507968 8th Mar 2019 1:43pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Believe me. Being under the fatty and forgetting to leave a door open, then hearing the eas valves start to adjust the height is a code brown moment!!! 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #508461 12th Mar 2019 5:59pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Been there, done it, never moved so fast, a very unsettling sound Shocked .
Post #508480 12th Mar 2019 7:50pm
Fraynizzle
can you explain what state the car was in when the adjustment started?
was it jacked up from body or suspension?
where were the axle stands etc?
my interpretation from reading the manual is that when you are jacking the body up it detects the wheel dropping too slowly to be a road input and assumes it is being jacked up and inhibits any adjustments until the same height is reached again i.e. when letting the body back down.
if you are not jacking the vehicle using the body i think this is when you run into issues because the vehicle doesn't detect it is being jacked because the wheels are moving up with the body and not going slowly into droop.
like i said ive always lifted the car in line with the manual and never had any issues.
Post #508530 13th Mar 2019 9:17am
Strider
Done when I was replacing all brake pipes,
I was using a combination of 3 ton trolley jack, 4.. 3 ton axle stands and my ramps. Sorry I cant remember the exact details
but all I can say is it tried to level the body. My drive has a slight slope in 2 directions so doesn't really help the situation.
The movement was very slight only about 10-20mm, its the sound of air escaping that surprised me, the doors were shut.
Post #508549 13th Mar 2019 10:55am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Maybe not the same, but I jacked my Disco 4 up at the weekend.
off road height and door open.
As soon as the jack started to lift (placed under the suspension arm), there was a hissing and the wheel lifted itself up off the floor. Never been so easy. Must have thought it was grounded or something Mr. Green
Post #508563 13th Mar 2019 12:50pm
this extract from the WM explains how to jack up the FF,
http://www.fullfatrr.com/gallery/albums/us...acking.pdf
Post #508574 13th Mar 2019 2:36pm
