Home > Maintenance & Mods (L322) > Best way to jack one side of the FF |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Opening doors, putting hazard lights on etc. does nothing - hence why it’s not mentioned in the handbook. |
7th Mar 2019 10:25pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
That's not true. Opening a door interrupts a suspension height change for safety reasons. It may not prevent adjustments but it stops a change between access / standard / exetended height. It even shows up on the info display when it happens. 2016 Skoda Octavia VRS Estate
7th Mar 2019 10:52pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
It used to be the tailgate as well as any doors on the P38A - I believe the hazard warning lights were simply that:
8th Mar 2019 12:06am |
Maybe not for just changing a wheel. But anytime a part of me is going to go between a sprung piece of the FF and an unsprung piece (or anything else that's fixed), I do it. Anything that easy to do that might prevent a height change seems worthwhile to me. 2016 Skoda Octavia VRS Estate
8th Mar 2019 9:24am |
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 |
the manual only mentions jacking to lift the body, using jacking points and subframes not suspension arms.
8th Mar 2019 12:10pm |
from the workshop manual regarding air suspension inhibit modes, make of it what you will.
8th Mar 2019 1:43pm |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Believe me. Being under the fatty and forgetting to leave a door open, then hearing the eas valves start to adjust the height is a code brown moment!!! 2003 Range Rover Vogue 4.4 on Gas
12th Mar 2019 5:59pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Been there, done it, never moved so fast, a very unsettling sound . |
12th Mar 2019 7:50pm |
can you explain what state the car was in when the adjustment started?
13th Mar 2019 9:17am |
Done when I was replacing all brake pipes,
13th Mar 2019 10:55am |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Maybe not the same, but I jacked my Disco 4 up at the weekend.
13th Mar 2019 12:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
this extract from the WM explains how to jack up the FF,
13th Mar 2019 2:36pm |
