![]() | Home > Technical (L322) > Heavy Steering FIXED ! |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
Well done !
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Brilliant- thank you for the update on the fix! |
Gavin,
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
I also have sporadic heavy steering but always seems to be on lift off when slowing down like slowing and turning into a driveway etc. so revs are dropping when the issue presents itself.
Sounds like you could have the same cause or possibly sticking servotronic valve.Try Gavin's test.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Just fixed the heavy steering on my Td6.
Richcl, Well done. It's always satisfying to get the problem solved.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Got an issue with mine this week, wont self centre after going round sharp corners or junctions, steering gets stiff/heavy at the 10 and 2 oclock positions noticeably.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 726 ![]() ![]() |
Hmm yours sounds like a seized / seizing U joint on the steering column Welshdragon.
Yes, lower uj was the cause and when FF went in for MOT I got the mechanic to sort it......mind they change the lower 4 arms too as it failed the MOT on them!!
Great to hear you got it sorted welshdragon.
Sadly my servotronic valve didn't turn up Saturday so no progress on mine yet.
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 ![]() ![]() |
[ i had them all changed to save chasing the issue, now steering is fine, so the issue was flow and not pressure due to a hose collapsing under vacuum |
Mike4.4 Member Since: 30 Jun 2021 Location: Yorkshire Posts: 5 ![]() ![]() ![]() |
I cant help directly with your question but defo +1 for recommending those guys. Have done many power steering pumps for me over the years excellent service and prices, what ever the actual cost is I am sure it will be good value for money. |
